iPhone 6 Front Panel Replacement
  1. iPhone 6 Front Panel Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Front Panel Replacement, Tape over the display: step 2, image 1 of 3 iPhone 6 Front Panel Replacement, Tape over the display: step 2, image 2 of 3 iPhone 6 Front Panel Replacement, Tape over the display: step 2, image 3 of 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6 Front Panel Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 6 Front Panel Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 6 Front Panel Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6 Front Panel Replacement: step 4, image 1 of 3 iPhone 6 Front Panel Replacement: step 4, image 2 of 3 iPhone 6 Front Panel Replacement: step 4, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6 Front Panel Replacement, Manual Opening Procedure: step 5, image 1 of 1
    Anti-Clamp
    $24.95
    Buy
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6 Front Panel Replacement: step 6, image 1 of 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. iPhone 6 Front Panel Replacement: step 7, image 1 of 2 iPhone 6 Front Panel Replacement: step 7, image 2 of 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  8. iPhone 6 Front Panel Replacement, Opening up the phone: step 8, image 1 of 3 iPhone 6 Front Panel Replacement, Opening up the phone: step 8, image 2 of 3 iPhone 6 Front Panel Replacement, Opening up the phone: step 8, image 3 of 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Front Panel Replacement: step 9, image 1 of 3 iPhone 6 Front Panel Replacement: step 9, image 2 of 3 iPhone 6 Front Panel Replacement: step 9, image 3 of 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 6 Front Panel Replacement, Removing the battery connector bracket screws: step 10, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  11. iPhone 6 Front Panel Replacement: step 11, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 6 Front Panel Replacement, Disconnecting the battery connector: step 12, image 1 of 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  13. iPhone 6 Front Panel Replacement, Removing the front panel assembly cable bracket screws: step 13, image 1 of 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  14. iPhone 6 Front Panel Replacement: step 14, image 1 of 1
    • Remove the front panel assembly cable bracket from the logic board.
  15. iPhone 6 Front Panel Replacement: step 15, image 1 of 2 iPhone 6 Front Panel Replacement: step 15, image 2 of 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  16. iPhone 6 Front Panel Replacement: step 16, image 1 of 2 iPhone 6 Front Panel Replacement: step 16, image 2 of 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  17. iPhone 6 Front Panel Replacement: step 17, image 1 of 2 iPhone 6 Front Panel Replacement: step 17, image 2 of 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  18. iPhone 6 Front Panel Replacement: step 18, image 1 of 2 iPhone 6 Front Panel Replacement: step 18, image 2 of 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  19. iPhone 6 Front Panel Replacement, Separating front panel assembly and rear case: step 19, image 1 of 1
    • Remove the front panel assembly from the rear case.
  20. iPhone 6 Front Panel Replacement, Earpiece Speaker: step 20, image 1 of 1
    • Remove the following Phillips screws from the earpiece speaker/front-facing camera bracket:
    • One 2.3 mm screw
    • One 3.0 mm screw
    • One 2.2 mm screw
  21. iPhone 6 Front Panel Replacement: step 21, image 1 of 2 iPhone 6 Front Panel Replacement: step 21, image 2 of 2
    • Remove the earpiece speaker/front-facing camera bracket from the front panel.
  22. iPhone 6 Front Panel Replacement: step 22, image 1 of 2 iPhone 6 Front Panel Replacement: step 22, image 2 of 2
    • Lift the front-facing camera out of its recess in the front panel.
  23. iPhone 6 Front Panel Replacement: step 23, image 1 of 2 iPhone 6 Front Panel Replacement: step 23, image 2 of 2
    • Holding the front-facing camera out of the way, remove the earpiece speaker from the front panel.
    • Try not to touch any of the contacts on the speaker or the cable—skin oils can damage them and interrupt the connection. If you touch them by mistake, clean them with a little isopropyl alcohol and give them a few moments to air dry.
  24. iPhone 6 Front Panel Replacement, Front-Facing Camera and Sensor Cable: step 24, image 1 of 2 iPhone 6 Front Panel Replacement, Front-Facing Camera and Sensor Cable: step 24, image 2 of 2
    • Keeping the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
  25. iPhone 6 Front Panel Replacement: step 25, image 1 of 2 iPhone 6 Front Panel Replacement: step 25, image 2 of 2
    • Fold the front-facing camera and sensor cable up to allow access to the microphone.
  26. iPhone 6 Front Panel Replacement: step 26, image 1 of 2 iPhone 6 Front Panel Replacement: step 26, image 2 of 2
    • Carefully pry the microphone end of the sensor cable off of the adhesive holding it to the front panel.
  27. iPhone 6 Front Panel Replacement: step 27, image 1 of 1
    • Remove the front-facing camera and sensor cable from the front panel.
  28. iPhone 6 Front Panel Replacement, Home Button: step 28, image 1 of 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  29. iPhone 6 Front Panel Replacement: step 29, image 1 of 2 iPhone 6 Front Panel Replacement: step 29, image 2 of 2
    • Remove the home button bracket from the front panel.
  30. iPhone 6 Front Panel Replacement: step 30, image 1 of 2 iPhone 6 Front Panel Replacement: step 30, image 2 of 2
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
  31. iPhone 6 Front Panel Replacement: step 31, image 1 of 2 iPhone 6 Front Panel Replacement: step 31, image 2 of 2
    iOpener
    $19.99
    Buy
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
  32. iPhone 6 Front Panel Replacement: step 32, image 1 of 2 iPhone 6 Front Panel Replacement: step 32, image 2 of 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  33. iPhone 6 Front Panel Replacement: step 33, image 1 of 2 iPhone 6 Front Panel Replacement: step 33, image 2 of 2
    iOpener
    $12.99
    Buy
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  34. iPhone 6 Front Panel Replacement: step 34, image 1 of 1
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
  35. iPhone 6 Front Panel Replacement, Front Panel: step 35, image 1 of 3 iPhone 6 Front Panel Replacement, Front Panel: step 35, image 2 of 3 iPhone 6 Front Panel Replacement, Front Panel: step 35, image 3 of 3
    • Remove the following Phillips #00 screws securing the LCD shield plate to the front panel:
    • One 1.7 mm screw
    • Six 1.6 mm screws (three on each side)
  36. iPhone 6 Front Panel Replacement: step 36, image 1 of 2 iPhone 6 Front Panel Replacement: step 36, image 2 of 2
    • Lift the front-facing camera end of the LCD shield plate up slightly.
    • Do not attempt to remove the shield plate entirely, it is still attached to the front panel by the adhered-down home button cable.
  37. iPhone 6 Front Panel Replacement: step 37, image 1 of 3 iPhone 6 Front Panel Replacement: step 37, image 2 of 3 iPhone 6 Front Panel Replacement: step 37, image 3 of 3
    • Slide the point of a spudger behind the shield plate to gently peel the home button cable up off of the front panel.
    • The home button cable is very thin, go slowly and be careful not to rip it.
    • Remove the LCD shield plate.
Sam Goldheart
466,147 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 18
Past 7 Days: 91
Past 30 Days: 434
All Time: 927,713
