Samsung Galaxy Note10 Plus 5G Rear Cover Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
99
All Time:
4,213
Comments: 4
4 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the rear cover on your Samsung Galaxy Note10+ 5G.
This guide uses steps written for the non-5G Note10+. Some images in this guide may show minor discontinuities. They shouldn’t affect the overall guide procedure.
Parts
Tools
    1. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: step 3, image 1 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: step 3, image 2 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: step 4, image 1 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: step 4, image 2 of 3 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: step 4, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      Ask FixBot
    5. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Lift off the rear cover: step 5, image 1 of 2 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Lift off the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
4 other people completed this guide.
Arthur Shi
351,874 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 99
All Time: 4,213
