Introduction
Prereq-only for detaching the display assembly.
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
Insert an opening pick into the gap under the display on the lower edge of the iPhone.
Skip the next two steps.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Insert your pick into the right edge of the phone. Slide it around the top-right corner and across the top edge.
If you haven't removed your suction handle or iSclack, remove it now.
Open the iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Tool used on this step:Magnetic Project Mat$19.95
Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a fingernail to disconnect the display cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove four screws securing the front sensor connector cover.
Three 1.1 mm-long screws
One 1.4 mm-long screw
Swing the cover up from the left until the small clip on the right unhooks.
Remove the cover.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
