iPhone 12 Front-Facing Cameras Replacement
  1. iPhone 12 Front-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 1 of 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Ask FixBot
  2. iPhone 12 Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Ask FixBot
  4. iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  5. iPhone 12 Front-Facing Cameras Replacement: step 5, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement: step 5, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement: step 5, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  6. iPhone 12 Front-Facing Cameras Replacement: step 6, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement: step 6, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement: step 6, image 3 of 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Ask FixBot
  7. iPhone 12 Front-Facing Cameras Replacement, Heat the bottom edge: step 7, image 1 of 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    Ask FixBot
  8. iPhone 12 Front-Facing Cameras Replacement, Apply a suction cup: step 8, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Apply a suction cup: step 8, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
    Ask FixBot
  9. iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Ask FixBot
  10. iPhone 12 Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  11. iPhone 12 Front-Facing Cameras Replacement, Heat the right edge: step 11, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Heat the right edge: step 11, image 2 of 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    Ask FixBot
  12. iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 12, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 12, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 12, image 3 of 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
    Ask FixBot
  13. iPhone 12 Front-Facing Cameras Replacement, Heat the top edge: step 13, image 1 of 1
    • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
    Ask FixBot
  14. iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 14, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 14, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 14, image 3 of 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
    Ask FixBot
  15. iPhone 12 Front-Facing Cameras Replacement, Heat the left edge: step 15, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Heat the left edge: step 15, image 2 of 2
    • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
    Ask FixBot
  16. iPhone 12 Front-Facing Cameras Replacement, Separate the left adhesive: step 16, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the left adhesive: step 16, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the left adhesive: step 16, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick down the left edge of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Ask FixBot
  17. iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 17, image 3 of 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Ask FixBot
  18. iPhone 12 Front-Facing Cameras Replacement, Unscrew the battery and display connector cover: step 18, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Ask FixBot
  19. iPhone 12 Front-Facing Cameras Replacement, Remove the battery and display connector cover: step 19, image 1 of 1
    • Remove the cover.
    Ask FixBot
  20. iPhone 12 Front-Facing Cameras Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Ask FixBot
  21. iPhone 12 Front-Facing Cameras Replacement, Disconnect the display cable: step 21, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the display cable: step 21, image 2 of 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  22. iPhone 12 Front-Facing Cameras Replacement, Disconnect the digitizer cable: step 22, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the digitizer cable: step 22, image 2 of 2
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    Ask FixBot
  23. iPhone 12 Front-Facing Cameras Replacement, Unscrew the front sensor connector cover: step 23, image 1 of 1
    • Use a Y000 driver to remove four screws securing the front sensor connector cover.
    • Three 1.1 mm long screws
    • One 1.4 mm long screw
    Ask FixBot
  24. iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 24, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 24, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 24, image 3 of 3
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
    Ask FixBot
  25. iPhone 12 Front-Facing Cameras Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the front sensors: step 25, image 2 of 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
    Ask FixBot
  26. iPhone 12 Front-Facing Cameras Replacement, Remove the display assembly: step 26, image 1 of 1
    Ask FixBot
  27. iPhone 12 Front-Facing Cameras Replacement, Unscrew the front-facing camera assembly: step 27, image 1 of 1
    • Use a Y000 driver to remove the 1 mm long screw securing the front-facing camera assembly.
    Ask FixBot
  28. iPhone 12 Front-Facing Cameras Replacement, Remove the front-facing camera bracket: step 28, image 1 of 1
    • Lift up and remove the front-facing camera bracket.
    Ask FixBot
  29. iPhone 12 Front-Facing Cameras Replacement, Disconnect the front-facing camera assembly: step 29, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the front-facing camera assembly: step 29, image 2 of 2
    • Use a spudger or a fingernail to disconnect the Face ID dot projector cable from its socket on the logic board.
    Ask FixBot
  30. iPhone 12 Front-Facing Cameras Replacement: step 30, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement: step 30, image 2 of 2
    • Use a spudger or a fingernail to disconnect the Face ID sensor cable from its socket on the logic board.
    Ask FixBot
  31. iPhone 12 Front-Facing Cameras Replacement: step 31, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement: step 31, image 2 of 2
    • Gently push the Face ID cable connectors away from the logic board to access the selfie cam connector underneath.
    • Disconnect the selfie camera by prying its connector straight up.
    Ask FixBot
  32. iPhone 12 Front-Facing Cameras Replacement, Remove the front-facing camera assembly: step 32, image 1 of 1
    • Remove the front-facing camera assembly.
    Ask FixBot
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for help.
19 other people completed this guide.
Adam O'Camb
223,483 Reputation
416 Guides authored
1 Guide Comment
Tausch hat gut funktioniert, nur muss Face ID von Apple noch konfiguriert werden, das machen sie aber nicht wenn sie die frontkamera nicht selbst ausgetauscht haben. War das letzte applegerät.
Markus kro - Reply Share
Past 24 Hours: 19
Past 7 Days: 225
Past 30 Days: 646
All Time: 43,873
