iPad Air 7 11" Front Camera Replacement
    1. iPad Air 7 11" Front Camera Replacement, Safety precautions: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      • This guide is written with the iPad in portrait orientation.
      Ask FixBot
    2. iPad Air 7 11" Front Camera Replacement, Cracked screen preparation: step 2, image 1 of 1
      • Glass shards can complicate disassembly—or worse, cause injury. If your iPad has a cracked screen, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Only cover the glass itself—don't stick any tape to the frame.
      Ask FixBot
    1. iPad Air 7 11" Front Camera Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Position the suction cups near the top-left corner of the iPad—one on the top and one on the bottom. Make sure the arms don't block the speaker grille.
      • Place an object under your iPad so it rests level between the suction cups.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      Ask FixBot
    2. iPad Air 7 11" Front Camera Replacement: step 4, image 1 of 3 iPad Air 7 11" Front Camera Replacement: step 4, image 2 of 3 iPad Air 7 11" Front Camera Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPad Air 7 11" Front Camera Replacement: step 5, image 1 of 3 iPad Air 7 11" Front Camera Replacement: step 5, image 2 of 3 iPad Air 7 11" Front Camera Replacement: step 5, image 3 of 3
      • Use a hair dryer or heat gun to heat the screen area between the suction cups until it's slightly too hot to touch.
      • For complete instructions on how to heat with a hair dryer, check out this guide.
      • Improper use of a heat gun can destroy the screen and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick no deeper than 6 mm when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Remove the Anti-Clamp and skip the next two steps.
      Ask FixBot
    4. iPad Air 7 11" Front Camera Replacement, Suction handle instructions: step 6, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Suction handle instructions: step 6, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Suction handle instructions: step 6, image 3 of 3
      • The next two steps show how to use a suction handle to create an initial gap.
      • Use a hair dryer or heat gun to heat the top-left corner of the screen until it's slightly too hot to touch.
      • Apply a suction handle to the top-left edge of the screen (near the speaker grille).
      Ask FixBot
    5. iPad Air 7 11" Front Camera Replacement: step 7, image 1 of 3 iPad Air 7 11" Front Camera Replacement: step 7, image 2 of 3 iPad Air 7 11" Front Camera Replacement: step 7, image 3 of 3
      • Pull up on the suction handle with firm, constant pressure to create a gap under the screen.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert an opening pick into the gap, no deeper than 6 mm.
      Ask FixBot
    6. iPad Air 7 11" Front Camera Replacement, Separate the top edge adhesive: step 8, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Separate the top edge adhesive: step 8, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Separate the top edge adhesive: step 8, image 3 of 3
      • Heat the top edge of the iPad until it's slightly too hot to touch.
      • Insert another opening pick under the top-left corner of the screen.
      • Slide the pick along the top edge to separate the adhesive, making sure not to insert it deeper than 6 mm.
      • If you’re having trouble, apply more heat—not more force.
      • Leave the pick inserted in the corner to prevent the adhesive from resealing.
      Ask FixBot
    7. iPad Air 7 11" Front Camera Replacement, Separate the left edge adhesive: step 9, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Separate the left edge adhesive: step 9, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Separate the left edge adhesive: step 9, image 3 of 3
      • Don't insert opening picks deeper than 3 mm along the left edge to avoid damaging the screen.
      • Heat the left edge of the iPad until it's slightly too hot to touch.
      • Slide the pick along the left edge to separate the adhesive.
      Ask FixBot
    8. iPad Air 7 11" Front Camera Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Display cables run close to the bottom edge. Don't insert your pick deeper than 2 mm to avoid damaging the cables.
      • Heat the bottom edge until it's slightly too hot to touch.
      • Insert an opening pick under the bottom-left corner of the screen.
      • Slide the pick along the bottom edge to separate the adhesive, making sure not to insert it deeper than 2 mm.
      Ask FixBot
    9. iPad Air 7 11" Front Camera Replacement, Separate the right edge adhesive: step 11, image 1 of 3 iPad Air 7 11" Front Camera Replacement, Separate the right edge adhesive: step 11, image 2 of 3 iPad Air 7 11" Front Camera Replacement, Separate the right edge adhesive: step 11, image 3 of 3
      • Heat the right edge (the edge with the front-facing camera) until it's slightly too hot to touch.
      • Slowly open the iPad by swinging the screen up from the left edge, like the back cover of a book.
      • Don't try to remove the screen yet, as several fragile ribbon cables still connect it to the iPad. Take care not to strain the cables as you work.
      • If the screen feels hard to swing, apply more heat to the right edge.
      • If the screen feels stuck, use your pick to separate any missed sections of adhesive.
      Ask FixBot
    10. iPad Air 7 11" Front Camera Replacement: step 12, image 1 of 3 iPad Air 7 11" Front Camera Replacement: step 12, image 2 of 3 iPad Air 7 11" Front Camera Replacement: step 12, image 3 of 3
      • Use one hand to support the loose screen.
      • Use an opening pick to carefully separate the right edge adhesive.
      • Work slowly and watch where the pick slices to avoid damaging the display cables and front-facing camera components. If the adhesive feels hard to slice, apply more heat.
      Ask FixBot
    11. iPad Air 7 11" Front Camera Replacement, Prop the screen: step 13, image 1 of 1
      • Lean the screen against something to keep it propped up while you're working on the iPad.
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    1. iPad Air 7 11" Front Camera Replacement, Remove the front camera: step 14, image 1 of 2 iPad Air 7 11" Front Camera Replacement, Remove the front camera: step 14, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the front camera connector.
      Ask FixBot
    2. iPad Air 7 11" Front Camera Replacement: step 15, image 1 of 2 iPad Air 7 11" Front Camera Replacement: step 15, image 2 of 2
      Tesa 61395 Tape
      $2.95
      Buy
      • Use the point of a spudger to pry up the front camera.
      • Remove the front camera.
      • During reassembly, clean off any adhesive residue, then use double-sided tape to secure the camera to the frame.
      Ask FixBot
Arthur Shi
349,680 Reputation
930 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 109
All Time: 109
