Shop the Holiday Gift Guide
Screen Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
28
All Time:
736
Comments: 30
30 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Screen Removal
Introduction
Go to step 1 ↓
Use this guide to replace a broken, cracked, or defective display on your Apple Watch Series 4.
Make sure to update your Apple Watch to watchOS 5 or later (and the paired iPhone to iOS 12 or later) to avoid pairing issues after a display replacement.
Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed.
This guide shows the procedure on the standard, GPS-only version of the watch, but the cellular/LTE version is similar.
Parts
Tools
    1. Screen Removal, Display Opening: step 1, image 1 of 2 Screen Removal, Display Opening: step 1, image 2 of 2
      Ask FixBot
    2. Screen Removal, Safety Requirements: step 2, image 1 of 3 Screen Removal, Safety Requirements: step 2, image 2 of 3 Screen Removal, Safety Requirements: step 2, image 3 of 3
      • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
      • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
      • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
      • Wear eye protection. The knife or glass may break, sending pieces flying.
      • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
      Ask FixBot
    3. Screen Removal: step 3, image 1 of 1
      • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
      • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
      • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
      Ask FixBot
    4. Screen Removal: step 4, image 1 of 3 Screen Removal: step 4, image 2 of 3 Screen Removal: step 4, image 3 of 3
      • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
      • Press firmly straight down into the gap.
      • Once inserted, tilt the blade to pry the display open slightly.
      • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
      Ask FixBot
    5. Screen Removal: step 5, image 1 of 2 Screen Removal: step 5, image 2 of 2
      • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
      • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
      • Don't try to fully open or detach the display yet.
      Ask FixBot
    6. Screen Removal: step 6, image 1 of 3 Screen Removal: step 6, image 2 of 3 Screen Removal: step 6, image 3 of 3
      • It's likely that the Force Touch sensor will stick to the display frame instead of the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
      • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
      • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
      • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
      Ask FixBot
    7. Screen Removal: step 7, image 1 of 3 Screen Removal: step 7, image 2 of 3 Screen Removal: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • To avoid straining the display cables, don't open the display all the way yet.
      • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
      • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
      • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
      Ask FixBot
    1. Screen Removal, Battery: step 8, image 1 of 2 Screen Removal, Battery: step 8, image 2 of 2
      • Carefully fold the screen to the back until you get enough space to pry out the battery.
      • Avoid tensioning the display cables when folding the screen to the back.
      • Insert an opening pick between the battery and the Taptic Engine.
      • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
      Ask FixBot
    2. Screen Removal: step 9, image 1 of 3 Screen Removal: step 9, image 2 of 3 Screen Removal: step 9, image 3 of 3
      • Slide the opening pick along the edge of the battery to loosen the adhesive.
      • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
      • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
      • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
      • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
      • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
      Ask FixBot
    3. Screen Removal: step 10, image 1 of 2 Screen Removal: step 10, image 2 of 2
      Buy
      • Carefully lift the battery and bring it in a 75° angle.
      • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
      Ask FixBot
    4. Screen Removal: step 11, image 1 of 1
      • Remove the Y000 screw (1.2 mm length).
      Ask FixBot
    5. Screen Removal: step 12, image 1 of 2 Screen Removal: step 12, image 2 of 2
      • Use a pair of tweezers to remove the metal plate which covers the battery connector.
      Ask FixBot
    6. Screen Removal: step 13, image 1 of 2 Screen Removal: step 13, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    7. Screen Removal: step 14, image 1 of 2 Screen Removal: step 14, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the battery.
      • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
      Ask FixBot
    1. Screen Removal, Screen Removal: step 15, image 1 of 2 Screen Removal, Screen Removal: step 15, image 2 of 2
      • The black foil which covers the display connectors is very fragile and likely to rip. To keep the tape intact while peeling it off, it's necessary to use high isopropyl alcohol or an iOpener.
      • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip and apply it to the black adhesive foil. Let it penetrate the adhesive for about two minutes.
      • Alternatively you can place an a heated iOpener on top of the screen to loosen the adhesive. Apply the iOpener at least for two minutes.
      Ask FixBot
    2. Screen Removal: step 16, image 1 of 1
      Buy
      • Use a pair of tweezers to carefully peel off the tape covering the three display cable connectors.
      Ask FixBot
    3. Screen Removal: step 17, image 1 of 3 Screen Removal: step 17, image 2 of 3 Screen Removal: step 17, image 3 of 3
      • Use one arm of a pair of tweezers to carfully open the three ZIF connectors on the rear side of the screen.
      Ask FixBot
    4. Screen Removal: step 18, image 1 of 3 Screen Removal: step 18, image 2 of 3 Screen Removal: step 18, image 3 of 3
      • Use a pair of blunt nose tweezers to peel up the sides of the black foil which adheres the cable to the rear side of the screen.
      Ask FixBot
    5. Screen Removal: step 19, image 1 of 3 Screen Removal: step 19, image 2 of 3 Screen Removal: step 19, image 3 of 3
      • Lift the body of the watch up and carefully slide a spudger underneath the display flex cable to loosen remaining adhesive.
      Ask FixBot
    6. Screen Removal: step 20, image 1 of 3 Screen Removal: step 20, image 2 of 3 Screen Removal: step 20, image 3 of 3
      • Carefully pull the display flex cables out of their ZIF connectors.
      • Make sure to hold on to the display flex cable during this procedure and avoid pulling only on the body of the watch. Otherwise the display cable might rip.
      • Separate the watch assembly and the screen.
      Ask FixBot
Author
with
Dominik Schnabelrauch
267,846 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 28
All Time: 736
