Samsung Galaxy Note10+ 5G Screen Replacement
  1. Samsung Galaxy Note10+ 5G Screen Replacement, Heat the rear cover: step 1, image 1 of 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: step 3, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: step 3, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: step 3, image 3 of 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: step 4, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: step 4, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: step 4, image 3 of 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Samsung Galaxy Note10+ 5G Screen Replacement, Lift off the rear cover: step 5, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Lift off the rear cover: step 5, image 2 of 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
  6. Samsung Galaxy Note10+ 5G Screen Replacement, Lift up the metal cover: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  7. Samsung Galaxy Note10+ 5G Screen Replacement: step 7, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement: step 7, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement: step 7, image 3 of 3
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  8. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the battery: step 8, image 2 of 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  9. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  10. Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: step 10, image 3 of 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
  11. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the display cable: step 11, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the display cable: step 11, image 2 of 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the touch layer: step 12, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the touch layer: step 12, image 2 of 2
    • Use the pointed end of a spudger to disconnect the S-Pen touch layer cable connector from the motherboard.
  13. Samsung Galaxy Note10+ 5G Screen Replacement, Loosen the adhesive: step 13, image 1 of 1
    • Prepare an iOpener and apply it to the left edge of the display for one minute.
  14. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: step 14, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: step 14, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: step 14, image 3 of 3
    • Apply a suction cup to the heated edge of the display, as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
    • Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
  15. Samsung Galaxy Note10+ 5G Screen Replacement: step 15, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement: step 15, image 2 of 2
    • Slide the opening pick along the left side towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
  16. Samsung Galaxy Note10+ 5G Screen Replacement: step 16, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement: step 16, image 2 of 2
    • Insert a second opening pick and slide it along the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
  17. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the bottom side adhesive: step 17, image 1 of 1
    • Prepare an iOpener and apply it to the bottom edge of the phone for one minute.
  18. Samsung Galaxy Note10+ 5G Screen Replacement: step 18, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement: step 18, image 2 of 2
    • Insert a third opening pick into the gap on the bottom edge of the phone.
    • Slide the opening pick to the bottom right corner, slicing the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  19. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the top side adhesive: step 19, image 1 of 1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
  20. Samsung Galaxy Note10+ 5G Screen Replacement: step 20, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement: step 20, image 2 of 2
    • Insert a fourth opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
  21. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the right side adhesive: step 21, image 1 of 1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
  22. Samsung Galaxy Note10+ 5G Screen Replacement: step 22, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement: step 22, image 2 of 2
    • Slide the opening pick from the top right corner down towards the bottom right corner of the phone to slice the adhesive.
    • The display will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
  23. Samsung Galaxy Note10+ 5G Screen Replacement, Remove the screen: step 23, image 1 of 2 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the screen: step 23, image 2 of 2
    • Don't try to completely remove the screen yet, as there are still some cables routed through the phone's frame.
    • Lift the screen up from the top edge of the phone.
    • Don't lift the screen higher than about a 15º angle above the device.
  24. Samsung Galaxy Note10+ 5G Screen Replacement: step 24, image 1 of 3 Samsung Galaxy Note10+ 5G Screen Replacement: step 24, image 2 of 3 Samsung Galaxy Note10+ 5G Screen Replacement: step 24, image 3 of 3
    • Thread the display and S-Pen touch layer cables through their cutouts on the phone frame.
    • Remove the display.
    • Remove any leftover adhesive before installing a new display.
    • Follow this guide for instructions on how to apply adhesive to the replacement screen.
    • Be sure to test your repairs before installing new adhesives.
Arthur Shi
253,349 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,187 Guides authored
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 144
All Time: 5,184
