Introduction
This guide demonstrates how to disconnect the antenna cable in your Google Pixel 8 Pro. This is required before removing the earpiece speaker and the logic board.
Unplug all cables from your phone.
Completely power off your phone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
Tool used on this step:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
Slide the arms over the left edge of your phone, so you have access to the bottom edge.
Position the suction cups as close to the center of the bottom edge as possible.
Squeeze the cups together to create suction.
Pull the handle forward to lock the arms.
Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
Wait one minute for a gap to form between the screen and frame.
Insert an opening pick into the gap.
Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
Skip the next two steps.
Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
Slide the opening pick along the bottom edge to separate the adhesive securing it.
Leave the pick in the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the screen for two minutes.
Insert a second opening pick under the bottom right corner of the screen.
Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
Leave the pick in the top right corner to prevent the adhesive from resealing.
Insert a third opening pick under the bottom edge of the screen.
Slide the new pick to the bottom left corner.
Leave the pick in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
Insert a fourth opening pick under the bottom left corner of the screen.
Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
Leave the pick in the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Insert a fifth opening pick under the top edge of the screen, near the left corner.
Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
Swing up the right edge of the screen like the front cover of a book.
Prop up the screen so you can access the screen cable without straining it.
Use an opening tool to pry up the upper edge of the screen cable cover.
Remove the cover.
Insert the point of a spudger under the top right corner of the screen's press connector.
Gently pry up and disconnect the cable.
Remove the screen.
Use the pull tabs to remove the liners covering the front camera cutout, the back of the screen, and the perimeter adhesive.
Reconnect the screen cable and reinstall its cover.
This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
Press firmly around the perimeter of the screen to secure it with the new adhesive.
Follow this guide to calibrate the fingerprint sensor.
Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
Heat an iOpener and lay it on the 5G mmWave antenna cable for two minutes to soften the adhesive.
Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
Twist the spudger to separate the bottom of the cable from the midframe.
Tool used on this step:Tesa 61395 Tape$5.99
Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
Peel up and remove the entire graphite sheet.
Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
Remove the larger rectangular liner from the shim.
Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
Use the flat end of a spudger to firmly press down along the whole shim to secure it.
Remove the remaining liner.
Tool used on this step:FixMat$36.95
Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
Remove the cover.
Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
Use the point of a spudger to pry up and disconnect the battery cable press connector.
Use the point of a spudger to pry up and disconnect the front camera press connector.
Use the point of a spudger to pry up and disconnect all three rear camera press connectors from the top edge of the logic board.
Use a T3 Torx screwdriver to remove the two screws securing the rear camera assembly:
One 3.5 mm‑long 3IP Torx Plus screw securing the top left corner
One 5 mm‑long 3IP Torx Plus screw securing the top right corner
Insert a spudger between the right edge of the rear camera assembly and frame.
Pry the rear camera assembly up and remove it.
Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the top left corner of the logic board.
Gently lift straight up to disconnect the cable.
