Nintendo Switch Screen Replacement
  1. Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    Ask FixBot
  2. Nintendo Switch Screen Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Screen Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Screen Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    Ask FixBot
  3. Nintendo Switch Screen Replacement, Remove the back-side screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    Ask FixBot
  4. Nintendo Switch Screen Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Screen Replacement, Remove the top and bottom screws: step 4, image 2 of 2
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    Ask FixBot
  5. Nintendo Switch Screen Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Screen Replacement, Remove the center side screws: step 5, image 2 of 2
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    Ask FixBot
  6. Nintendo Switch Screen Replacement: step 6, image 1 of 2 Nintendo Switch Screen Replacement: step 6, image 2 of 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    Ask FixBot
  7. Nintendo Switch Screen Replacement, Remove the kickstand well screw: step 7, image 1 of 1
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    Ask FixBot
  8. Nintendo Switch Screen Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Screen Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Screen Replacement, Remove the rear panel: step 8, image 3 of 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    Ask FixBot
  9. Nintendo Switch Screen Replacement, Remove the microSD card reader: step 9, image 1 of 1
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    Ask FixBot
  10. Nintendo Switch Screen Replacement: step 10, image 1 of 2 Nintendo Switch Screen Replacement: step 10, image 2 of 2
    Buy
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    Ask FixBot
  11. Nintendo Switch Screen Replacement, Remove the shield plate: step 11, image 1 of 1
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    Ask FixBot
  12. Nintendo Switch Screen Replacement: step 12, image 1 of 2 Nintendo Switch Screen Replacement: step 12, image 2 of 2
    Buy
    • If the console doesn't have this foam, skip this step.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    Ask FixBot
  13. Nintendo Switch Screen Replacement: step 13, image 1 of 3 Nintendo Switch Screen Replacement: step 13, image 2 of 3 Nintendo Switch Screen Replacement: step 13, image 3 of 3
    iFixit Thermal Putty
    $9.95
    Buy
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    Ask FixBot
  14. Nintendo Switch Screen Replacement, Disconnect the battery: step 14, image 1 of 2 Nintendo Switch Screen Replacement, Disconnect the battery: step 14, image 2 of 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Ask FixBot
  15. Nintendo Switch Screen Replacement, Remove the heat sink: step 15, image 1 of 1
    • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Ask FixBot
  16. Tool used on this step:
    iFixit Adhesive Remover
    $19.99
    Buy
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
    • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
    Ask FixBot
  17. Nintendo Switch Screen Replacement: step 17, image 1 of 3 Nintendo Switch Screen Replacement: step 17, image 2 of 3 Nintendo Switch Screen Replacement: step 17, image 3 of 3
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
    Ask FixBot
  18. Nintendo Switch Screen Replacement, Remove the headphone jack and game card reader: step 18, image 1 of 2 Nintendo Switch Screen Replacement, Remove the headphone jack and game card reader: step 18, image 2 of 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    Ask FixBot
  19. Nintendo Switch Screen Replacement: step 19, image 1 of 2 Nintendo Switch Screen Replacement: step 19, image 2 of 2
    Buy
    • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
    • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
    • With the cable parallel to the board, gently slide it into its connector.
    • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
    • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
    Ask FixBot
  20. Nintendo Switch Screen Replacement: step 20, image 1 of 2 Nintendo Switch Screen Replacement: step 20, image 2 of 2
    • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
    Ask FixBot
  21. Nintendo Switch Screen Replacement: step 21, image 1 of 1
    • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
    Ask FixBot
  22. Nintendo Switch Screen Replacement: step 22, image 1 of 2 Nintendo Switch Screen Replacement: step 22, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
    Ask FixBot
  23. Nintendo Switch Screen Replacement: step 23, image 1 of 2 Nintendo Switch Screen Replacement: step 23, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
    Ask FixBot
  24. Nintendo Switch Screen Replacement, Screen: step 24, image 1 of 2 Nintendo Switch Screen Replacement, Screen: step 24, image 2 of 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
    Ask FixBot
  25. Nintendo Switch Screen Replacement: step 25, image 1 of 2 Nintendo Switch Screen Replacement: step 25, image 2 of 2
    Buy
    • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
    Ask FixBot
  26. Nintendo Switch Screen Replacement: step 26, image 1 of 2 Nintendo Switch Screen Replacement: step 26, image 2 of 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
    Ask FixBot
  27. Nintendo Switch Screen Replacement: step 27, image 1 of 2 Nintendo Switch Screen Replacement: step 27, image 2 of 2
    Ask FixBot
  28. Nintendo Switch Screen Replacement: step 28, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
    Ask FixBot
  29. Nintendo Switch Screen Replacement: step 29, image 1 of 3 Nintendo Switch Screen Replacement: step 29, image 2 of 3 Nintendo Switch Screen Replacement: step 29, image 3 of 3
    • Apply a suction cup to the bottom-left corner of the screen.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
    Ask FixBot
  30. Nintendo Switch Screen Replacement: step 30, image 1 of 3 Nintendo Switch Screen Replacement: step 30, image 2 of 3 Nintendo Switch Screen Replacement: step 30, image 3 of 3
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
    Ask FixBot
  31. Nintendo Switch Screen Replacement: step 31, image 1 of 3 Nintendo Switch Screen Replacement: step 31, image 2 of 3 Nintendo Switch Screen Replacement: step 31, image 3 of 3
    • Insert a second opening pick into the gap to the left of the first pick.
    • Slide the opening pick back towards the left side of the device.
    • Leave the opening pick inserted.
    Ask FixBot
  32. Nintendo Switch Screen Replacement: step 32, image 1 of 1
    • Heat the left edge of the screen for around two minutes to help soften the adhesive.
    Ask FixBot
  33. Nintendo Switch Screen Replacement: step 33, image 1 of 3 Nintendo Switch Screen Replacement: step 33, image 2 of 3 Nintendo Switch Screen Replacement: step 33, image 3 of 3
    • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
    Ask FixBot
  34. Nintendo Switch Screen Replacement: step 34, image 1 of 2 Nintendo Switch Screen Replacement: step 34, image 2 of 2
    • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
    Ask FixBot
  35. Nintendo Switch Screen Replacement: step 35, image 1 of 1
    • Heat the top edge of the screen for around two minutes to help soften the adhesive.
    Ask FixBot
  36. Nintendo Switch Screen Replacement: step 36, image 1 of 3 Nintendo Switch Screen Replacement: step 36, image 2 of 3 Nintendo Switch Screen Replacement: step 36, image 3 of 3
    • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
    Ask FixBot
  37. Nintendo Switch Screen Replacement: step 37, image 1 of 3 Nintendo Switch Screen Replacement: step 37, image 2 of 3 Nintendo Switch Screen Replacement: step 37, image 3 of 3
    • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
    Ask FixBot
  38. Nintendo Switch Screen Replacement: step 38, image 1 of 3 Nintendo Switch Screen Replacement: step 38, image 2 of 3 Nintendo Switch Screen Replacement: step 38, image 3 of 3
    • Heat the right edge of the screen for around two minutes to help soften the adhesive.
    • Place the flat end of a spudger into the gap along the left edge of the screen.
    • Carefully and slowly lift the left edge of the screen, opening it like a book.
    Ask FixBot
  39. Nintendo Switch Screen Replacement: step 39, image 1 of 3 Nintendo Switch Screen Replacement: step 39, image 2 of 3 Nintendo Switch Screen Replacement: step 39, image 3 of 3
    • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your new screen doesn’t work properly after you boot up the device, turn it back off and disconnect and reconnect the battery connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
57 other people completed this guide.
Craig Lloyd
42,881 Reputation
82 Guides authored
4 Guide Comments
What size tesa tape best fits the original (not OLED) switch? I have a slightly loose screen and don't want to disassemble to measure without having the right size on hand.
pvantilb05 - Reply Share
I followed the steps, however the screen only works/lights up if I push on the screen. Any idea what I did wrong?
Hannah Henderson - Reply Share
The Screen and Screen assembly are out of stock...can I buy the LCD, Digitizer etc and assemble them myself?
James Bowkett - Reply Share
Step 27 - I pulled the ribbon connector off the board. Can I solder it back on?
mmhekh - Reply Share
Past 24 Hours: 38
Past 7 Days: 461
Past 30 Days: 1,675
All Time: 120,538
