Dismantle Nespresso CitiZ
  1. Dismantle Nespresso CitiZ, Dismantle Nespresso CitiZ: step 1, image 1 of 1
    • Never forget: pull the plug!
    • Remove all attachments: Water tank, capsule and cup drawer, drip tray.
    • The model shown is also equipped with a milk frother, remove that too.
  2. Dismantle Nespresso CitiZ: step 2, image 1 of 2 Dismantle Nespresso CitiZ: step 2, image 2 of 2
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • The bottom is secured by oval head screws.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Nespresso wants to keep us out of our own machines!!!
    • Remove five oval head screws securing the large bottom panel.
    • Note: this panel is smaller on models without milk frother.
  3. Dismantle Nespresso CitiZ: step 3, image 1 of 3 Dismantle Nespresso CitiZ: step 3, image 2 of 3 Dismantle Nespresso CitiZ: step 3, image 3 of 3
    • The bottom panel is just snapped into place. Insert a metal spudger into the slots and lift the panel out. It sits quite tightly and you might use some force to get it out.
  4. Dismantle Nespresso CitiZ: step 4, image 1 of 1
    • Remove the large bottom panel.
  5. Dismantle Nespresso CitiZ: step 5, image 1 of 1
    • Use a spudger to slide off the two silicon tubes.
  6. Dismantle Nespresso CitiZ: step 6, image 1 of 2 Dismantle Nespresso CitiZ: step 6, image 2 of 2
    • Disconnect the two spade plugs on the blue and brown wires from the power switch. The two left ones remain.
  7. Dismantle Nespresso CitiZ: step 7, image 1 of 1
    • Remove four oval head screws from the small bottom panel.
    • Remove the main device from the base. It´s still connected with some wires, but this doesn´t bother much.
  8. Dismantle Nespresso CitiZ: step 8, image 1 of 3 Dismantle Nespresso CitiZ: step 8, image 2 of 3 Dismantle Nespresso CitiZ: step 8, image 3 of 3
    • The two colored side panels are only snapped into place. However, the latches sit very tight. You really need a lot of force. First lift the lower edge using a plastic opening tool.
    • Depending from the model it might help, when you first pry off the coffee spout. (See next step)
    • Unfold each of the side panels upwards and remove them.
  9. Dismantle Nespresso CitiZ: step 9, image 1 of 1
    • Insert a opening tool in the gap on the bottom of the coffee spout. Pry it off carefully.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,941 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,129 Guides authored
2 Comments
Wie geht es weiter um an die Heizung zu kommen? Vermutlich ist eine Reperatur nicht möglich.
Martin Gastberger - Reply
Ich denke der Teardown zeigt es: Nespresso CitiZ Teardown
VauWeh -
Past 24 Hours: 12
Past 7 Days: 132
Past 30 Days: 592
All Time: 9,774
