MacBook Neo Logic Board Replacement
    1. MacBook Neo Logic Board Replacement, Prepare the MacBook for disassembly: step 1, image 1 of 3 MacBook Neo Logic Board Replacement, Prepare the MacBook for disassembly: step 1, image 2 of 3 MacBook Neo Logic Board Replacement, Prepare the MacBook for disassembly: step 1, image 3 of 3
      • Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
      • Disconnect any cables and accessories.
      • Flip the computer upside‑down on a clean work surface.
      Ask FixBot
    1. MacBook Neo Logic Board Replacement, Remove the bottom cover screws: step 2, image 1 of 1
      • Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
      • Six 4.1 mm‑long screws
      • Two 4.5 mm‑long screws
      • During reassembly, partially install the screws to ensure alignment, then tighten the screws at each corner (like top‑right, bottom‑left, etc.) before the rest.
      Ask FixBot
    2. MacBook Neo Logic Board Replacement, Pry up the bottom cover: step 3, image 1 of 3 MacBook Neo Logic Board Replacement, Pry up the bottom cover: step 3, image 2 of 3 MacBook Neo Logic Board Replacement, Pry up the bottom cover: step 3, image 3 of 3
      • The bottom cover is held in place with two clips, one on each side.
      • Use your fingers to lift the top right corner of the bottom cover, near the USB‑C ports, until the clip along the right edge releases.
      • If you're having trouble, use the flat end of a spudger to pry up the corner until you can grab it with your fingers. You can also slide an opening pick down each edge to release the clips.
      • Repeat this process on the left side to release its clip.
      Ask FixBot
    3. MacBook Neo Logic Board Replacement, Remove the bottom cover: step 4, image 1 of 2 MacBook Neo Logic Board Replacement, Remove the bottom cover: step 4, image 2 of 2
      • Remove the bottom cover.
      • During reassembly, align the bottom cover with its screw holes, then press on the two short sides until the clip on each side snaps into place.
      Ask FixBot
    1. MacBook Neo Logic Board Replacement, Remove the battery connector cover: step 5, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the battery connector cover.
      • While the MacBook Neo uses Torx Plus screws, standard Torx bits also work (T3 in place of 3IP, for example). Apply constant, downward force to prevent stripping the screw.
      Ask FixBot
    2. MacBook Neo Logic Board Replacement: step 6, image 1 of 2 MacBook Neo Logic Board Replacement: step 6, image 2 of 2
      • Use tweezers or your fingers to remove the battery connector cover.
      Ask FixBot
    3. MacBook Neo Logic Board Replacement, Disconnect the battery: step 7, image 1 of 2 MacBook Neo Logic Board Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery press connector.
      • To reconnect, align the connector carefully over its socket and press down—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    1. MacBook Neo Logic Board Replacement, Remove the antenna connector cover: step 8, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the 1.7 mm‑long screw securing the antenna connector cover.
      Ask FixBot
    2. MacBook Neo Logic Board Replacement: step 9, image 1 of 2 MacBook Neo Logic Board Replacement: step 9, image 2 of 2
      • Use tweezers or your fingers to remove the antenna connector cover.
      • During reassembly, make sure the edge with a protrusion is facing the antenna.
      Ask FixBot
    3. MacBook Neo Logic Board Replacement, Disconnect the antenna: step 10, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the antenna: step 10, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the antenna: step 10, image 3 of 3
      • Insert one arm of angled tweezers under the metal neck of one of the antenna coaxial connectors and lift straight up to disconnect it.
      • Repeat the process to disconnect the second antenna cable.
      • To reconnect, use tweezers to hold each connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      Ask FixBot
    4. MacBook Neo Logic Board Replacement, Remove the USB ports connector cover: step 11, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the USB ports connector cover.
      Ask FixBot
    5. MacBook Neo Logic Board Replacement: step 12, image 1 of 2 MacBook Neo Logic Board Replacement: step 12, image 2 of 2
      • Use tweezers or your fingers to remove the USB ports connector cover.
      Ask FixBot
    6. MacBook Neo Logic Board Replacement, Disconnect the USB ports: step 13, image 1 of 2 MacBook Neo Logic Board Replacement, Disconnect the USB ports: step 13, image 2 of 2
      • Use the flat end of a spudger to disconnect the USB ports press connector.
      Ask FixBot
    7. MacBook Neo Logic Board Replacement, Disconnect the right speaker: step 14, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the right speaker: step 14, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the right speaker: step 14, image 3 of 3
      • Insert the point of a spudger beneath the right speaker connector, located on the left side of the logic board directly above the battery, and pry it straight up to disconnect it.
      Ask FixBot
    8. MacBook Neo Logic Board Replacement, Disconnect the headphone jack and left speaker: step 15, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the headphone jack and left speaker: step 15, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the headphone jack and left speaker: step 15, image 3 of 3
      Ask FixBot
    9. MacBook Neo Logic Board Replacement, Disconnect the display cable: step 16, image 1 of 2 MacBook Neo Logic Board Replacement, Disconnect the display cable: step 16, image 2 of 2
      • Use the flat end of a spudger to gently push under the metal buckle of the display cable connector, located on the top‑right corner of the logic board, to unclip it.
      Ask FixBot
    10. MacBook Neo Logic Board Replacement: step 17, image 1 of 2 MacBook Neo Logic Board Replacement: step 17, image 2 of 2
      • Grab the buckle and cable together and gently pull the connector straight out of its socket.
      Ask FixBot
    11. MacBook Neo Logic Board Replacement, Disconnect the camera: step 18, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the camera: step 18, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the camera: step 18, image 3 of 3
      • Repeat this procedure to disconnect the camera cable, located on the left edge of the logic board.
      • To reconnect:
      • Grip the buckle and insert the connector fully into its socket. Realign it as necessary but don't try to force it in.
      • Flip the buckle over the socket and press it down until it clicks into place.
      Ask FixBot
    12. MacBook Neo Logic Board Replacement, Lift the keyboard cable cover: step 19, image 1 of 2 MacBook Neo Logic Board Replacement, Lift the keyboard cable cover: step 19, image 2 of 2
      • Don't tear or fully remove this cover—it'll be used to disconnect the cable.
      • Use tweezers to peel up the black sticker over the keyboard cable, just until it comes off the socket on the board. Make sure it stays attached to the cable.
      Ask FixBot
    13. MacBook Neo Logic Board Replacement, Disconnect the keyboard: step 20, image 1 of 2 MacBook Neo Logic Board Replacement, Disconnect the keyboard: step 20, image 2 of 2
      • Use the flat end of a spudger to flip up the hinged locking flap on the keyboard cable ZIF connector.
      Ask FixBot
    14. MacBook Neo Logic Board Replacement: step 21, image 1 of 2 MacBook Neo Logic Board Replacement: step 21, image 2 of 2
      • Use tweezers or your fingers to gently grip the keyboard cable by its cover and slide the cable out of its socket.
      Ask FixBot
    15. MacBook Neo Logic Board Replacement, Disconnect the microphone and trackpad: step 22, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the microphone and trackpad: step 22, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the microphone and trackpad: step 22, image 3 of 3
      • Repeat the procedure to disconnect the microphone and trackpad cable ZIF connectors, adjacent to the keyboard cable connector.
      Ask FixBot
    16. MacBook Neo Logic Board Replacement, Disconnect the Touch ID sensor: step 23, image 1 of 3 MacBook Neo Logic Board Replacement, Disconnect the Touch ID sensor: step 23, image 2 of 3 MacBook Neo Logic Board Replacement, Disconnect the Touch ID sensor: step 23, image 3 of 3
      • If the laptop doesn't have Touch ID, skip this step.
      • Disconnect the Touch ID cable ZIF connector, located on the left edge of the logic board.
      Ask FixBot
    17. MacBook Neo Logic Board Replacement, Move the cables: step 24, image 1 of 3 MacBook Neo Logic Board Replacement, Move the cables: step 24, image 2 of 3 MacBook Neo Logic Board Replacement, Move the cables: step 24, image 3 of 3
      • Move the cables out of the way of the logic board.
      Ask FixBot
    18. MacBook Neo Logic Board Replacement, Remove the logic board screws: step 25, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the five 1.7 mm‑long screws securing the logic board.
      Ask FixBot
    19. MacBook Neo Logic Board Replacement, Remove the logic board: step 26, image 1 of 3 MacBook Neo Logic Board Replacement, Remove the logic board: step 26, image 2 of 3 MacBook Neo Logic Board Replacement, Remove the logic board: step 26, image 3 of 3
      • Carefully lift the logic board around the cables and out of the MacBook.
      • Use your fingers or a spudger to free any cables that get snagged as you lift the board.
      Ask FixBot
    20. MacBook Neo Logic Board Replacement, Check cables during reassembly: step 27, image 1 of 1
      • When you reinstall the logic board, verify that no cables get trapped under the board as you lower it into place:
      • Keyboard, microphone, and trackpad cables
      • Audio board cable
      • USB ports cable
      • Touch ID board cable (if present)
      Ask FixBot
Compare the new replacement part to the original part—you may need to remove protective covers from the new part before you install it.
To reassemble the MacBook, follow these instructions in reverse order.
Nick Schultz
65,500 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 79
Past 30 Days: 335
All Time: 1,105
