Logitech G915 Wireless (Clicky) Battery Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
153
All Time:
2,511
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Logitech G915 TKL wireless keyboard.
Lithium-ion batteries have a limited lifespan. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 15% charge—this is indicated when the battery light on the top edge of the keyboard is red. While your G915 TKL keyboard has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
If your battery looks puffy or swollen, take extra precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
      • Slide the power switch on the top edge of the keyboard to the OFF (left) position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the keyboard.
      • Lay the keyboard down with the feet facing up on a clean work surface.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: step 2, image 1 of 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: step 2, image 2 of 2
      • The Logitech sticker hides two battery cover screws.
      • Heat an iOpener and lay it on the Logitech sticker for one minute.
      • Alternatively, you can use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
      Ask FixBot
    2. Logitech G915 Wireless (Clicky) Battery Replacement: step 3, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement: step 3, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement: step 3, image 3 of 3
      • If you don't want to remove the whole sticker, you can just peel up the bottom left and right corners until you can access the screws.
      • Use a spudger or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
      • Peel up the sticker with your fingers and remove it.
      Ask FixBot
    3. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: step 4, image 1 of 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
      Ask FixBot
    4. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: step 5, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: step 5, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: step 5, image 3 of 3
      • If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
      Ask FixBot
    5. Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: step 6, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: step 6, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: step 6, image 3 of 3
      • Plastic clips secure the edges of the battery cover.
      • Insert your finger into the USB receiver compartment on the battery cover.
      • Pull up the bottom edge of the cover to release the clips.
      • Don't try to fully remove the cover yet, as it's still connected by the battery cable.
      • Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
      Ask FixBot
    6. Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: step 7, image 1 of 2 Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use a pair of angled tweezers to firmly grip the battery connector.
      • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
      • Slide the connector straight out of its socket.
      • If you're having trouble, gently rock the connector side-to-side to help loosen it.
      Ask FixBot
    7. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover: step 8, image 1 of 1
      • Remove the battery cover.
      • Congratulations on completing disassembly! The remaining steps will show you how to install your replacement battery and reassemble your device.
      Ask FixBot
    8. Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: step 9, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: step 9, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: step 9, image 3 of 3
      • If your replacement battery comes attached to a new battery cover, skip the next three steps. Otherwise, follow the next three steps to remove the old battery from the cover and install your new one.
      • Light adhesive secures the battery to its cover.
      • Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
      • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
      • Remove the battery from its cover.
      Ask FixBot
    9. Logitech G915 Wireless (Clicky) Battery Replacement: step 10, image 1 of 3 Logitech G915 Wireless (Clicky) Battery Replacement: step 10, image 2 of 3 Logitech G915 Wireless (Clicky) Battery Replacement: step 10, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Cut a piece of double-sided tape so it fits on the line of squares on the inside of the battery cover.
      • Press the tape firmly into place on the squares and remove the liner.
      Ask FixBot
    10. Logitech G915 Wireless (Clicky) Battery Replacement: step 11, image 1 of 1
      • Lay your new battery into its recess in the keyboard so the cable is on the left edge, near the battery connector.
      Ask FixBot
    11. Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: step 12, image 1 of 2 Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: step 12, image 2 of 2
      • Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
      • Use a spudger to push the battery connector fully into its socket.
      Ask FixBot
    12. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover: step 13, image 1 of 1
      • Set the battery cover into place and firmly press down around its edges to engage all the clips.
      • You should feel and hear "clicks" as the clips engage.
      Ask FixBot
    13. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: step 14, image 1 of 2 Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: step 14, image 2 of 2
      • Use a Phillips screwdriver to install the two 4 mm‑long screws securing the battery cover.
      Ask FixBot
    14. Logitech G915 Wireless (Clicky) Battery Replacement, Apply the battery cover sticker: step 15, image 1 of 1
      • Use your fingers to apply the sticker to the battery cover.
      • To help the sticker adhere better, you can apply some heat with an iOpener or hair dryer.
      Ask FixBot
Spencer Day
207,035 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 153
All Time: 2,511
