Shop the Holiday Gift Guide
Huawei Mate 20 Pro Battery Replacement
Views: 40K
View statistics:
Past 24 Hours:
7
Past 7 Days:
68
Past 30 Days:
277
All Time:
40,199
Comments: 20
3 comments on steps, 17 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Huawei Mate 20 Pro.
Opening the Huawei Mate 20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Although it is possible to remove the battery without removing the main flex cable with the charging port, we recommend to do so to avoid damage to surrounding components.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Huawei Mate 20 Pro Battery Replacement, Rear Glass: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 2, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 2, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      Ask FixBot
    3. Huawei Mate 20 Pro Battery Replacement: step 3, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Huawei Mate 20 Pro Battery Replacement: step 4, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 4, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Huawei Mate 20 Pro Battery Replacement: step 5, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Huawei Mate 20 Pro Battery Replacement: step 6, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Huawei Mate 20 Pro Battery Replacement: step 7, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 7, image 2 of 2
      • Lift and remove the back cover.
      • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Motherboard Cover with NFC & Charging Coil: step 8, image 1 of 1
      • Remove the eight Phillips #00 screws (4.3 mm length).
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 9, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 9, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 9, image 3 of 3
      • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
      • Carefully slide the opening from the left to the right side to loosen the adhesive.
      Ask FixBot
    3. Huawei Mate 20 Pro Battery Replacement: step 10, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 10, image 2 of 2
      • Insert an opening pick under the bottom left corner of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      • Do not try to remove the motherboard cover all the way yet. The flex cable of the flash assembly is still connected to the motherboard.
      Ask FixBot
    4. Huawei Mate 20 Pro Battery Replacement: step 11, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 11, image 2 of 2
      • Carefully fold the motherboard cover in the direction of the battery.
      • Take special care to avoid ripping the flash assembly flex cable as it is still connected to the motherboard.
      Ask FixBot
    5. Huawei Mate 20 Pro Battery Replacement: step 12, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 12, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 12, image 3 of 3
      • Use a spudger to pry up and disconnect the flash assembly flex cable.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      • Remove the motherboard cover including the NFC and charging coil.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Battery Disconnect: step 13, image 1 of 2 Huawei Mate 20 Pro Battery Replacement, Battery Disconnect: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Daughterboard Cover: step 14, image 1 of 1
      • Remove the three Phillips #00 screws (4.3 mm length).
      • If you want to remove or replace the loudspeaker, daughterboard, battery, or the OLED screen, remove the four Phillips #00 screws (4.3 mm length) which hold down the loudspeaker assembly.
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 15, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 15, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 15, image 3 of 3
      Tool used on this step:
      Buy
      • Slide an opening pick under the top right corner of the daughterboard cover.
      • Use the opening pick to pry up the daughterboard cover. Remove the daughterboard cover with tweezers.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Loudspeaker & Daughterboard: step 16, image 1 of 2 Huawei Mate 20 Pro Battery Replacement, Loudspeaker & Daughterboard: step 16, image 2 of 2
      • Use a Spudger to pry up and disconnect the interconnect flex cable from the daughterboard.
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 17, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 17, image 2 of 2
      • Use a Spudger to pry up and disconnect the interconnect flex cable from the motherboard.
      • Remove the interconnect flex cable.
      Ask FixBot
    3. Huawei Mate 20 Pro Battery Replacement: step 18, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 18, image 2 of 2
      Buy
      • Use a pair of tweezers to pry up and disconnect the connector of the black coax cable from the daughterboard.
      • Unroute the black coax cable from the metal clip on the daughterboard and fold it to the side.
      Ask FixBot
    4. Huawei Mate 20 Pro Battery Replacement: step 19, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 19, image 2 of 2
      • Slide an opening underneath the top left corner of the loudspeaker cover.
      • Use the opening pick to pry up the loudspeaker and daughterboard assembly.
      Ask FixBot
    5. Huawei Mate 20 Pro Battery Replacement: step 20, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 20, image 2 of 2
      • Remove the loudspeaker and daughterboard assembly.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Charging Port with Main Flex Cable: step 21, image 1 of 2 Huawei Mate 20 Pro Battery Replacement, Charging Port with Main Flex Cable: step 21, image 2 of 2
      • Use a spudger to pry up and disconnect the main flex cable from the motherboard.
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 22, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 22, image 2 of 2
      • Use a spudger to pry up and disconnect the main flex cable from the left daughterboard.
      Ask FixBot
    3. Huawei Mate 20 Pro Battery Replacement: step 23, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 23, image 2 of 2
      • Slide the flat end of a spudger under the right side of the main flex cable next to the charging port.
      • Use the spudger to pry up the main flex cable and to lever the charging port out of its recess.
      Ask FixBot
    4. Huawei Mate 20 Pro Battery Replacement: step 24, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 24, image 2 of 2
      • Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
      Ask FixBot
    1. Huawei Mate 20 Pro Battery Replacement, Battery: step 25, image 1 of 2 Huawei Mate 20 Pro Battery Replacement, Battery: step 25, image 2 of 2
      • Peel the orange adhesive strip labeled with a 1 off the battery. The orange adhesive tape will rip along a small perforated line.
      Ask FixBot
    2. Huawei Mate 20 Pro Battery Replacement: step 26, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 26, image 2 of 2
      • Peel the orange adhesive strip labeled with a 2 off the battery. The orange adhesive tape will rip along a small perforated line.
      Ask FixBot
    3. Huawei Mate 20 Pro Battery Replacement: step 27, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 27, image 2 of 2
      • Peel the orange adhesive strip labeled with a 3 off the battery.
      • Pull up the orange adhesive strip to lift the battery out of its recess.
      • Although these new adhesive tabs are supposed to make the battery removal easier, these may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display, to loosen the adhesive underneath.
      Ask FixBot
    4. Huawei Mate 20 Pro Battery Replacement: step 28, image 1 of 3 Huawei Mate 20 Pro Battery Replacement: step 28, image 2 of 3 Huawei Mate 20 Pro Battery Replacement: step 28, image 3 of 3
      • Swing the battery up to an upright position.
      • Peel the battery off the remaining adhesive.
      • Remove the battery.
      • During re-assembly, temporarily re-connect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      Ask FixBot
    5. Huawei Mate 20 Pro Battery Replacement: step 29, image 1 of 2 Huawei Mate 20 Pro Battery Replacement: step 29, image 2 of 2
      • Peel the battery's adhesive sticker off the midframe.
      • This step is mandatory if you are replacing the screen. However it is highly recommended to use a fresh adhesive sticker as well, when installing a new battery.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
15 other people completed this guide.
Dominik Schnabelrauch
267,552 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,955 Guides authored
17 Guide Comments
I have tried this with two new batteries now. I believe the device was water damaged by plugging the charger in while there was moisture in the port. The existing battery works but doesn't fast charge and gets very hot when charging, the battery also drains extremely quickly. Everytime insert a new battery the phone just get stuck in a boot loop, bringing up the Huawei powered by android screen before restarting, I have also replaced the charging port in hopes that may of been damaged and was causing the issue but this didn't work either. Any suggestion?
Joel Celnik - Reply Share
Excellent Step by step guide thank you
Labony Kitchen - Reply Share
Mate 20 battery has a serial number and is locked to the device. Replace it and get bootlooping confirmed on more than 5 devices so far. Don't understand why this isn't more common knowledge. I've had to do battery pcb swaps for a year now.
Alex Jax - Reply Share
Battery replacement also results in Bootloop here - factory reset not helping. Safe mode also not working.
Nick Ceo - Reply Share
I solved it by reusing the board at the base of the battery body
T,hisa - Reply Share
Past 24 Hours: 7
Past 7 Days: 68
Past 30 Days: 277
All Time: 40,199
