Shop the Holiday Gift Guide
Graphite Sheet Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
18
All Time:
314
Comments: 23
23 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prereq for peeling off the 5G mmWave antenna cable and removing the graphite sheet.
Tools
    1. Graphite Sheet Removal, Prepare your Pixel for disassembly: step 1, image 1 of 3 Graphite Sheet Removal, Prepare your Pixel for disassembly: step 1, image 2 of 3 Graphite Sheet Removal, Prepare your Pixel for disassembly: step 1, image 3 of 3
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Completely power off your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      Ask FixBot
    1. Graphite Sheet Removal, Mark your opening picks: step 2, image 1 of 3 Graphite Sheet Removal, Mark your opening picks: step 2, image 2 of 3 Graphite Sheet Removal, Mark your opening picks: step 2, image 3 of 3
      • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    2. Graphite Sheet Removal, Heat the bottom edge adhesive: step 3, image 1 of 1
      • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
      Ask FixBot
    3. Graphite Sheet Removal, Secure the Anti-Clamp: step 4, image 1 of 3 Graphite Sheet Removal, Secure the Anti-Clamp: step 4, image 2 of 3 Graphite Sheet Removal, Secure the Anti-Clamp: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
      • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
      • Position the suction cups as close to the center of the bottom edge as possible.
      • Squeeze the cups together to create suction.
      Ask FixBot
    4. Graphite Sheet Removal, Twist the handle: step 5, image 1 of 3 Graphite Sheet Removal, Twist the handle: step 5, image 2 of 3 Graphite Sheet Removal, Twist the handle: step 5, image 3 of 3
      • Pull the handle forward to lock the arms.
      • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
      • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
      Ask FixBot
    5. Graphite Sheet Removal, Insert an opening pick: step 6, image 1 of 3 Graphite Sheet Removal, Insert an opening pick: step 6, image 2 of 3 Graphite Sheet Removal, Insert an opening pick: step 6, image 3 of 3
      • Wait one minute for a gap to form between the screen and frame.
      • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
      • Insert an opening pick into the gap.
      • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
      • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
      • Skip the next two steps.
      Ask FixBot
    6. Graphite Sheet Removal, Apply a suction cup: step 7, image 1 of 2 Graphite Sheet Removal, Apply a suction cup: step 7, image 2 of 2
      • Apply a suction handle to the center of the screen's bottom edge.
      Ask FixBot
    7. Graphite Sheet Removal, Insert an opening pick: step 8, image 1 of 3 Graphite Sheet Removal, Insert an opening pick: step 8, image 2 of 3 Graphite Sheet Removal, Insert an opening pick: step 8, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • If you're having trouble creating a gap, apply more heat and try again.
      Ask FixBot
    8. Graphite Sheet Removal, Prevent damage to your phone: step 9, image 1 of 2 Graphite Sheet Removal, Prevent damage to your phone: step 9, image 2 of 2
      • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
      • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
      • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
      Ask FixBot
    9. Graphite Sheet Removal, Separate the bottom edge adhesive: step 10, image 1 of 3 Graphite Sheet Removal, Separate the bottom edge adhesive: step 10, image 2 of 3 Graphite Sheet Removal, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive securing it.
      • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    10. Graphite Sheet Removal, Heat the right edge adhesive: step 11, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      Ask FixBot
    11. Graphite Sheet Removal, Separate the right edge adhesive: step 12, image 1 of 3 Graphite Sheet Removal, Separate the right edge adhesive: step 12, image 2 of 3 Graphite Sheet Removal, Separate the right edge adhesive: step 12, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
      • Leave the pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    12. Graphite Sheet Removal, Leave a pick in the bottom left corner: step 13, image 1 of 3 Graphite Sheet Removal, Leave a pick in the bottom left corner: step 13, image 2 of 3 Graphite Sheet Removal, Leave a pick in the bottom left corner: step 13, image 3 of 3
      • Insert a third opening pick under the bottom edge of the screen.
      • Slide the new pick to the bottom left corner.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    13. Graphite Sheet Removal, Heat the left edge adhesive: step 14, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    14. Graphite Sheet Removal, Separate the left edge adhesive: step 15, image 1 of 3 Graphite Sheet Removal, Separate the left edge adhesive: step 15, image 2 of 3 Graphite Sheet Removal, Separate the left edge adhesive: step 15, image 3 of 3
      • Insert a fourth opening pick under the bottom left corner of the screen.
      • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
      • Leave the pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    15. Graphite Sheet Removal, Heat the top edge adhesive: step 16, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    16. Graphite Sheet Removal, Separate the top edge adhesive: step 17, image 1 of 2 Graphite Sheet Removal, Separate the top edge adhesive: step 17, image 2 of 2
      • Insert a fifth opening pick under the top edge of the screen, near the left corner.
      • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
      Ask FixBot
    17. Graphite Sheet Removal, Prop up the screen: step 18, image 1 of 2 Graphite Sheet Removal, Prop up the screen: step 18, image 2 of 2
      • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
      • Swing up the right edge of the screen like the front cover of a book.
      • Be careful not to strain the screen cable.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      • Prop up the screen so you can access the screen cable.
      Ask FixBot
    18. Graphite Sheet Removal, Remove the screen cable cover: step 19, image 1 of 3 Graphite Sheet Removal, Remove the screen cable cover: step 19, image 2 of 3 Graphite Sheet Removal, Remove the screen cable cover: step 19, image 3 of 3
      • Use an opening pick to pry up the upper edge of the screen cable cover.
      • Remove the cover.
      Ask FixBot
    19. Graphite Sheet Removal, Disconnect the screen: step 20, image 1 of 3 Graphite Sheet Removal, Disconnect the screen: step 20, image 2 of 3 Graphite Sheet Removal, Disconnect the screen: step 20, image 3 of 3
      • Insert the point of a spudger under the top left corner of the screen's press connector.
      • Gently pry up and disconnect the cable.
      • Remove the screen.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    20. Graphite Sheet Removal, Screen information: step 21, image 1 of 1
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Ask FixBot
    21. Graphite Sheet Removal, Remove the adhesive residue: step 22, image 1 of 3 Graphite Sheet Removal, Remove the adhesive residue: step 22, image 2 of 3 Graphite Sheet Removal, Remove the adhesive residue: step 22, image 3 of 3
      • The next two steps show how to install a new screen with pre-installed adhesive. If you're reusing your screen, follow this guide to apply adhesive to your old screen.
      • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
      • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
      Ask FixBot
    22. Graphite Sheet Removal: step 23, image 1 of 3 Graphite Sheet Removal: step 23, image 2 of 3 Graphite Sheet Removal: step 23, image 3 of 3
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
      • If you're having trouble, wrap the microfiber cloth around a spudger and use it to scrape the frame.
      Ask FixBot
    23. Graphite Sheet Removal, Reassembly information: step 24, image 1 of 3 Graphite Sheet Removal, Reassembly information: step 24, image 2 of 3 Graphite Sheet Removal, Reassembly information: step 24, image 3 of 3
      • Use the pull tabs to remove the liners covering the front camera cutout, the rear camera pad, the back of the screen, and the perimeter adhesive.
      • Reconnect the screen cable and reinstall its cover.
      • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
      • Firmly press the screen into place on the frame. You should feel the clips "pop" into place.
      • Press firmly around the perimeter of the screen to secure it with the new adhesive.
      • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
      • Follow this guide to calibrate the fingerprint sensor.
      Ask FixBot
    1. Graphite Sheet Removal, Disconnect the 5G mmWave antenna: step 25, image 1 of 3 Graphite Sheet Removal, Disconnect the 5G mmWave antenna: step 25, image 2 of 3 Graphite Sheet Removal, Disconnect the 5G mmWave antenna: step 25, image 3 of 3
      • Use the point of the spudger to pry up and disconnect the 5G mmWave antenna cable from the logic board.
      Ask FixBot
    2. Graphite Sheet Removal, Heat the 5G mmWave antenna cable: step 26, image 1 of 2 Graphite Sheet Removal, Heat the 5G mmWave antenna cable: step 26, image 2 of 2
      • The 5G mmWave antenna cable is secured to the midframe with adhesive in two places.
      • Heat an iOpener and lay it on the left edge of the phone for two minutes to soften the cable adhesive.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as, extreme heat can damage the battery.
      Ask FixBot
    3. Graphite Sheet Removal, Separate the adhesive: step 27, image 1 of 3 Graphite Sheet Removal, Separate the adhesive: step 27, image 2 of 3 Graphite Sheet Removal, Separate the adhesive: step 27, image 3 of 3
      • Insert an opening pick under the 5G mmWave antenna cable's bottom section of adhesive.
      • Slide the pick toward the top edge of the phone to separate the adhesive.
      Ask FixBot
    4. Graphite Sheet Removal: step 28, image 1 of 2 Graphite Sheet Removal: step 28, image 2 of 2
      • Repeat the previous step for the upper section of adhesive.
      Ask FixBot
    5. Graphite Sheet Removal, Reposition the 5G mmWave antenna cable: step 29, image 1 of 1
      • Move the 5G mmWave antenna cable over the top of the phone to keep it out of the way.
      • Don't fold or crease the cable—just move it enough so it doesn't interfere with disassembly.
      Ask FixBot
    6. Graphite Sheet Removal, Remove the graphite sheet: step 30, image 1 of 3 Graphite Sheet Removal, Remove the graphite sheet: step 30, image 2 of 3 Graphite Sheet Removal, Remove the graphite sheet: step 30, image 3 of 3
      • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
      • Insert the point of a spudger under the top right corner of the graphite sheet and lift until you can grip the sheet with your fingers.
      • Peel up and remove the entire graphite sheet.
      • If your sheet tears, don't worry! Grip the torn parts and remove the sheet in sections.
      • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
      Ask FixBot
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 314
