Apple Watch SE Battery Replacement
  1. Apple Watch SE Battery Replacement, Power down your watch: step 1, image 1 of 2 Apple Watch SE Battery Replacement, Power down your watch: step 1, image 2 of 2
  2. Apple Watch SE Battery Replacement, Safety requirements: step 2, image 1 of 3 Apple Watch SE Battery Replacement, Safety requirements: step 2, image 2 of 3 Apple Watch SE Battery Replacement, Safety requirements: step 2, image 3 of 3
    Tool used on this step:
    Safety Glasses
    $3.19
    Buy
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch SE Battery Replacement, Soften the display adhesive: step 3, image 1 of 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  4. Apple Watch SE Battery Replacement, Display opening: step 4, image 1 of 3 Apple Watch SE Battery Replacement, Display opening: step 4, image 2 of 3 Apple Watch SE Battery Replacement, Display opening: step 4, image 3 of 3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
  5. Apple Watch SE Battery Replacement: step 5, image 1 of 3 Apple Watch SE Battery Replacement: step 5, image 2 of 3 Apple Watch SE Battery Replacement: step 5, image 3 of 3
    • Insert an opening pick in the gap you've created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
  6. Apple Watch SE Battery Replacement: step 6, image 1 of 2 Apple Watch SE Battery Replacement: step 6, image 2 of 2
    • When slicing near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide the opening pick around the corner and along the long edge where the crown is located to cut the display adhesive.
  7. Apple Watch SE Battery Replacement: step 7, image 1 of 2 Apple Watch SE Battery Replacement: step 7, image 2 of 2
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge farthest away from the crown.
  8. Apple Watch SE Battery Replacement: step 8, image 1 of 2 Apple Watch SE Battery Replacement: step 8, image 2 of 2
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Slide an opening pick under the opposite display edge of the watch crown.
  9. Apple Watch SE Battery Replacement: step 9, image 1 of 2 Apple Watch SE Battery Replacement: step 9, image 2 of 2
    • Reinsert the opening pick on the short edge of the watch, next to the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
  10. Apple Watch SE Battery Replacement: step 10, image 1 of 3 Apple Watch SE Battery Replacement: step 10, image 2 of 3 Apple Watch SE Battery Replacement: step 10, image 3 of 3
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it in direction of the short edge farthest away from the crown.
    • Swing the display open to an upward position.
  11. Apple Watch SE Battery Replacement, Soften the battery adhesive: step 11, image 1 of 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the rear side of the watch to loosen the battery adhesive. Leave the iOpener on the watch for at least two minutes.
  12. Apple Watch SE Battery Replacement, Insert an opening pick: step 12, image 1 of 3 Apple Watch SE Battery Replacement, Insert an opening pick: step 12, image 2 of 3 Apple Watch SE Battery Replacement, Insert an opening pick: step 12, image 3 of 3
    • Lift the screen until there's enough space to access the battery.
    • Insert an opening pick between the battery and the Taptic Engine.
  13. Apple Watch SE Battery Replacement, Pry up the battery: step 13, image 1 of 3 Apple Watch SE Battery Replacement, Pry up the battery: step 13, image 2 of 3 Apple Watch SE Battery Replacement, Pry up the battery: step 13, image 3 of 3
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The battery adhesive is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Avoid damaging the display cables, and especially the force touch cable, which covers the battery in one corner during the prying procedure.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  14. Apple Watch SE Battery Replacement, Move the battery: step 14, image 1 of 3 Apple Watch SE Battery Replacement, Move the battery: step 14, image 2 of 3 Apple Watch SE Battery Replacement, Move the battery: step 14, image 3 of 3
    • The battery flex cable is long enough to allow you to place the battery outside the watch case, but avoid straining the cable when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess.
  15. Apple Watch SE Battery Replacement, Unfasten the battery connector screw: step 15, image 1 of 1
    • Use a Y000 driver to remove the 1.1 mm screw from the battery connector.
  16. Apple Watch SE Battery Replacement, Remove the metal plate: step 16, image 1 of 2 Apple Watch SE Battery Replacement, Remove the metal plate: step 16, image 2 of 2
    • Use a pair of tweezers to remove the metal plate covering the battery connector.
  17. Apple Watch SE Battery Replacement, Disconnect the battery: step 17, image 1 of 2 Apple Watch SE Battery Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  18. Apple Watch SE Battery Replacement, Free the battery connector: step 18, image 1 of 2 Apple Watch SE Battery Replacement, Free the battery connector: step 18, image 2 of 2
    • Use a pair of tweezers to carefully free the battery connector by peeling off the overlapping foil.
  19. Apple Watch SE Battery Replacement, Remove the Battery: step 19, image 1 of 2 Apple Watch SE Battery Replacement, Remove the Battery: step 19, image 2 of 2
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
Dominik Schnabelrauch
204,989 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 109
Past 7 Days: 713
Past 30 Days: 2,534
All Time: 44,562
