iPhone 16 Plus Microphone Replacement
  1. iPhone 16 Plus Microphone Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 16 Plus Microphone Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Ask FixBot
  2. iPhone 16 Plus Microphone Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Plus Microphone Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 16 Plus Microphone Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Plus Microphone Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Plus Microphone Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 16 Plus Microphone Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
    Ask FixBot
  5. iPhone 16 Plus Microphone Replacement, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Plus Microphone Replacement, Heat the bottom edge: step 5, image 2 of 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 16 Plus Microphone Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Plus Microphone Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Plus Microphone Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 16 Plus Microphone Replacement, Back glass information: step 7, image 1 of 2 iPhone 16 Plus Microphone Replacement, Back glass information: step 7, image 2 of 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    Ask FixBot
  8. iPhone 16 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contacts.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
    Ask FixBot
  9. iPhone 16 Plus Microphone Replacement, Heat the right edge: step 9, image 1 of 2 iPhone 16 Plus Microphone Replacement, Heat the right edge: step 9, image 2 of 2
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
    Ask FixBot
  10. iPhone 16 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 16 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 16 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the spring contacts and ribbon cable.
    • Slide your pick around the bottom right corner and slide it halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Ask FixBot
  11. iPhone 16 Plus Microphone Replacement, Heat the left edge: step 11, image 1 of 2 iPhone 16 Plus Microphone Replacement, Heat the left edge: step 11, image 2 of 2
    Ask FixBot
  12. iPhone 16 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 16 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 16 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the left edge to avoid damaging the spring contact.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  13. iPhone 16 Plus Microphone Replacement, Heat the top edge: step 13, image 1 of 2 iPhone 16 Plus Microphone Replacement, Heat the top edge: step 13, image 2 of 2
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
    • When using a hair dryer or heat gun, heat until it's hot to the touch.
    Ask FixBot
  14. iPhone 16 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 16 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 16 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You should hear and feel clicks as the top two clips release.
    Ask FixBot
  15. iPhone 16 Plus Microphone Replacement, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Plus Microphone Replacement, Swing open the back glass: step 15, image 2 of 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    Ask FixBot
  16. iPhone 16 Plus Microphone Replacement, Unfasten the middle connector cover: step 16, image 1 of 2 iPhone 16 Plus Microphone Replacement, Unfasten the middle connector cover: step 16, image 2 of 2
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the middle connector cover.
    Ask FixBot
  17. iPhone 16 Plus Microphone Replacement, Remove the middle connector cover: step 17, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the middle connector cover: step 17, image 2 of 2
    • Be careful not to dent or puncture the battery during this step.
    • Use blunt-nose tweezers or your fingers to slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
    Ask FixBot
  18. iPhone 16 Plus Microphone Replacement, Disconnect the wireless charger: step 18, image 1 of 2 iPhone 16 Plus Microphone Replacement, Disconnect the wireless charger: step 18, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
    Ask FixBot
  19. iPhone 16 Plus Microphone Replacement, Remove the back glass: step 19, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the back glass: step 19, image 2 of 2
    • Lift the back glass off the frame and remove it.
    Ask FixBot
  20. iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine bracket screws: step 20, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine bracket screws: step 20, image 2 of 2
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine bracket:
    • Two 1.9 mm‑long screws
    • One 2.1 mm‑long screw
    Ask FixBot
  21. iPhone 16 Plus Microphone Replacement: step 21, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 21, image 2 of 2
    • Use tweezers or your fingers to remove the Taptic Engine bracket.
    Ask FixBot
  22. iPhone 16 Plus Microphone Replacement, Disconnect the Taptic Engine: step 22, image 1 of 2 iPhone 16 Plus Microphone Replacement, Disconnect the Taptic Engine: step 22, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the Taptic Engine press connector.
    Ask FixBot
  23. iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine screw: step 23, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine screw: step 23, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the Taptic Engine.
    Ask FixBot
  24. iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine: step 24, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the Taptic Engine: step 24, image 2 of 2
    • Use blunt-nose tweezers or your fingers to pick up and remove the Taptic Engine.
    Ask FixBot
  25. iPhone 16 Plus Microphone Replacement, Remove the loudspeaker screws: step 25, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the loudspeaker screws: step 25, image 2 of 2
    Tool used on this step:
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Be careful not to puncture or dent the battery with your screwdriver.
    • Use your Phillips screwdriver to remove four of the screws securing the loudspeaker:
    • Three 1.5 mm-long screws
    • One 3.0 mm-long screw
    • Use your tri-point Y000 screwdriver to remove the 1.3 mm-long screw securing a grounding contact and the loudspeaker.
    • Use your standoff screwdriver to remove the 3.4 mm-long screw securing the loudspeaker.
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
    Ask FixBot
  26. iPhone 16 Plus Microphone Replacement, Remove the loudspeaker: step 26, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the loudspeaker: step 26, image 2 of 2
    • Grab the loudspeaker and remove it.
    Ask FixBot
  27. iPhone 16 Plus Microphone Replacement, Disconnect the microphone: step 27, image 1 of 2 iPhone 16 Plus Microphone Replacement, Disconnect the microphone: step 27, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the microphone's press connector.
    • Don't pry against the battery, it could catch fire if damaged.
    Ask FixBot
  28. iPhone 16 Plus Microphone Replacement, Remove the microphone screws: step 28, image 1 of 2 iPhone 16 Plus Microphone Replacement, Remove the microphone screws: step 28, image 2 of 2
    • Remove the four screws securing the microphone:
    • One 3.3 mm‑long standoff screw
    • One 1.3 mm‑long tri-point Y000 screw
    • One 1.5 mm‑long Phillips screw
    • One 1.3 mm‑long Phillips screw
    Ask FixBot
  29. iPhone 16 Plus Microphone Replacement, Remove the microphone: step 29, image 1 of 3 iPhone 16 Plus Microphone Replacement, Remove the microphone: step 29, image 2 of 3 iPhone 16 Plus Microphone Replacement, Remove the microphone: step 29, image 3 of 3
    • The microphone is held in place by strong adhesive to the bottom edge of the phone.
    • Insert the flat end of a spudger under the top edge of the microphone and pry up until you can grab it with your fingers.
    • If the microphone does not budge, try adding a little bit of heat using an iOpener, hair dryer, or heat gun. Only heat it it's slightly hot to touch, as the battery is susceptible to heat damage.
    • Peel the microphone from the adhesive securing it to the frame and remove it.
    Ask FixBot
  30. iPhone 16 Plus Microphone Replacement, Disassembly complete: step 30, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Some reassembly photos are of the iPhone 16 non‑Plus, which may look slightly different. The procedure is correct.
    Ask FixBot
  31. iPhone 16 Plus Microphone Replacement, Prepare the adhesive: step 31, image 1 of 1
    • Peel away the new adhesive strip from its white liner, keeping the blue liner in place.
    • Don't stick the adhesive to the microphone yet.
    Ask FixBot
  32. iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 32, image 1 of 3 iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 32, image 2 of 3 iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 32, image 3 of 3
    • Once the adhesive sticks to the microphone, it cannot be removed and reused. Ensure it is perfectly aligned before adhering.
    • Align the two holes in the adhesive with the three holes in the microphone, and stick it into place.
    Ask FixBot
  33. iPhone 16 Plus Microphone Replacement: step 33, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 33, image 2 of 2
    • Use tweezers or your fingers to remove the blue plastic liner.
    Ask FixBot
  34. iPhone 16 Plus Microphone Replacement, Install the microphone: step 34, image 1 of 3 iPhone 16 Plus Microphone Replacement, Install the microphone: step 34, image 2 of 3 iPhone 16 Plus Microphone Replacement, Install the microphone: step 34, image 3 of 3
    • Align the microphone with its screw holes and set it into the frame.
    • Press the microphone against the bottom edge of the frame once it's perfectly aligned.
    Ask FixBot
  35. iPhone 16 Plus Microphone Replacement, Secure the microphone: step 35, image 1 of 2 iPhone 16 Plus Microphone Replacement, Secure the microphone: step 35, image 2 of 2
    • Partially install (don't fully tighten) the four screws securing the microphone:
    Ask FixBot
  36. iPhone 16 Plus Microphone Replacement: step 36, image 1 of 1
    • Squeeze the microphone against the bottom of the frame for 15 seconds to compress the adhesive.
    Ask FixBot
  37. iPhone 16 Plus Microphone Replacement: step 37, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 37, image 2 of 2
    • Fully tighten the four screws securing the microphone to the frame:
    • Two Phillips screws
    • One Tri-point Y000 screw
    • One Standoff screw
    Ask FixBot
  38. iPhone 16 Plus Microphone Replacement, Connect the microphone: step 38, image 1 of 2 iPhone 16 Plus Microphone Replacement, Connect the microphone: step 38, image 2 of 2
    • Use the flat end of a spudger to connect the microphone's press connector.
    Ask FixBot
  39. iPhone 16 Plus Microphone Replacement, Install the loudspeaker: step 39, image 1 of 3 iPhone 16 Plus Microphone Replacement, Install the loudspeaker: step 39, image 2 of 3 iPhone 16 Plus Microphone Replacement, Install the loudspeaker: step 39, image 3 of 3
    • Make sure the orange speaker gasket is fully in its slot in the frame.
    • Align the loudspeaker with its screw posts and set it into its recess.
    • Be careful not to move the orange speaker gasket during installation.
    Ask FixBot
  40. iPhone 16 Plus Microphone Replacement: step 40, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 40, image 2 of 2
    $5.49
    Buy
    • Use a Phillips screwdriver to install four of the screws securing the loudspeaker:
    • Three 1.5 mm‑long screws
    • One 3.0 mm‑long screw
    • Use a tri‑point Y000 screwdriver to install the 1.3 mm‑long screw securing a grounding contact and the loudspeaker.
    • Use a standoff screwdriver to install the 3.4 mm‑long screw securing the loudspeaker.
    Ask FixBot
  41. iPhone 16 Plus Microphone Replacement, Install the Taptic Engine: step 41, image 1 of 3 iPhone 16 Plus Microphone Replacement, Install the Taptic Engine: step 41, image 2 of 3 iPhone 16 Plus Microphone Replacement, Install the Taptic Engine: step 41, image 3 of 3
    • Use blunt-nose tweezers or your fingers to align the Taptic Engine with its screw posts and place it in the frame.
    Ask FixBot
  42. iPhone 16 Plus Microphone Replacement, Connect the Taptic Engine: step 42, image 1 of 2 iPhone 16 Plus Microphone Replacement, Connect the Taptic Engine: step 42, image 2 of 2
    • Use your finger or a spudger to connect the Taptic Engine press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side, then the other, until it clicks into place. Don't try to force the connector into place—if you're having trouble, reposition it and try again.
    Ask FixBot
  43. iPhone 16 Plus Microphone Replacement, Secure the Taptic Engine: step 43, image 1 of 2 iPhone 16 Plus Microphone Replacement, Secure the Taptic Engine: step 43, image 2 of 2
    • Use a Phillips screwdriver to install the 1.8 mm screw securing the Taptic Engine.
    Ask FixBot
  44. iPhone 16 Plus Microphone Replacement, Install the bracket: step 44, image 1 of 2 iPhone 16 Plus Microphone Replacement, Install the bracket: step 44, image 2 of 2
    • Align the Taptic Engine bracket with its screw holes and set it into place.
    Ask FixBot
  45. iPhone 16 Plus Microphone Replacement: step 45, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 45, image 2 of 2
    • Use a Phillips screwdriver to install the three screws securing the Taptic Engine bracket:
    Ask FixBot
  46. iPhone 16 Plus Microphone Replacement, Remove the back glass adhesive: step 46, image 1 of 3 iPhone 16 Plus Microphone Replacement, Remove the back glass adhesive: step 46, image 2 of 3 iPhone 16 Plus Microphone Replacement, Remove the back glass adhesive: step 46, image 3 of 3
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    Ask FixBot
  47. iPhone 16 Plus Microphone Replacement: step 47, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 47, image 2 of 2
    • Use the tweezers to pull the adhesive off of the phone.
    • Repeat the previous step and this step until all of the adhesive is removed.
    Ask FixBot
  48. iPhone 16 Plus Microphone Replacement, Clean the frame: step 48, image 1 of 3 iPhone 16 Plus Microphone Replacement, Clean the frame: step 48, image 2 of 3 iPhone 16 Plus Microphone Replacement, Clean the frame: step 48, image 3 of 3
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  49. iPhone 16 Plus Microphone Replacement, Clean the back glass: step 49, image 1 of 2 iPhone 16 Plus Microphone Replacement, Clean the back glass: step 49, image 2 of 2
    • If you're not reusing your back glass, skip this step.
    • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
    • If any clips on the back glass are bent, gently straighten them with your fingers.
    Ask FixBot
  50. iPhone 16 Plus Microphone Replacement, Orient the adhesive: step 50, image 1 of 2 iPhone 16 Plus Microphone Replacement, Orient the adhesive: step 50, image 2 of 2
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to ensure the adhesive is oriented correctly.
    Ask FixBot
  51. iPhone 16 Plus Microphone Replacement, Expose the bottom edge of the adhesive: step 51, image 1 of 1
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    Ask FixBot
  52. iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 52, image 1 of 3 iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 52, image 2 of 3 iPhone 16 Plus Microphone Replacement, Apply the adhesive: step 52, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    Ask FixBot
  53. iPhone 16 Plus Microphone Replacement: step 53, image 1 of 3 iPhone 16 Plus Microphone Replacement: step 53, image 2 of 3 iPhone 16 Plus Microphone Replacement: step 53, image 3 of 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Ask FixBot
  54. iPhone 16 Plus Microphone Replacement, Press the adhesive into place: step 54, image 1 of 3 iPhone 16 Plus Microphone Replacement, Press the adhesive into place: step 54, image 2 of 3 iPhone 16 Plus Microphone Replacement, Press the adhesive into place: step 54, image 3 of 3
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
    Ask FixBot
  55. iPhone 16 Plus Microphone Replacement, Remove the pink liner: step 55, image 1 of 3 iPhone 16 Plus Microphone Replacement, Remove the pink liner: step 55, image 2 of 3 iPhone 16 Plus Microphone Replacement, Remove the pink liner: step 55, image 3 of 3
    • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
    Ask FixBot
  56. iPhone 16 Plus Microphone Replacement: step 56, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 56, image 2 of 2
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
    Ask FixBot
  57. iPhone 16 Plus Microphone Replacement, Connect the charging coil: step 57, image 1 of 3 iPhone 16 Plus Microphone Replacement, Connect the charging coil: step 57, image 2 of 3 iPhone 16 Plus Microphone Replacement, Connect the charging coil: step 57, image 3 of 3
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector.
    Ask FixBot
  58. iPhone 16 Plus Microphone Replacement, Connect the battery: step 58, image 1 of 2 iPhone 16 Plus Microphone Replacement, Connect the battery: step 58, image 2 of 2
    • Use the flat end of a spudger or your finger to connect the battery.
    Ask FixBot
  59. iPhone 16 Plus Microphone Replacement, Install the cover: step 59, image 1 of 3 iPhone 16 Plus Microphone Replacement, Install the cover: step 59, image 2 of 3 iPhone 16 Plus Microphone Replacement, Install the cover: step 59, image 3 of 3
    • The connector cover has two hooks that slide into slots on the logic board.
    • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
    • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
    Ask FixBot
  60. iPhone 16 Plus Microphone Replacement, Install the cover screws: step 60, image 1 of 2 iPhone 16 Plus Microphone Replacement, Install the cover screws: step 60, image 2 of 2
    • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
    Ask FixBot
  61. iPhone 16 Plus Microphone Replacement, Remove the final adhesive liners: step 61, image 1 of 3 iPhone 16 Plus Microphone Replacement, Remove the final adhesive liners: step 61, image 2 of 3 iPhone 16 Plus Microphone Replacement, Remove the final adhesive liners: step 61, image 3 of 3
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
    Ask FixBot
  62. iPhone 16 Plus Microphone Replacement: step 62, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 62, image 2 of 2
    • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
    Ask FixBot
  63. iPhone 16 Plus Microphone Replacement, Place the back glass: step 63, image 1 of 3 iPhone 16 Plus Microphone Replacement, Place the back glass: step 63, image 2 of 3 iPhone 16 Plus Microphone Replacement, Place the back glass: step 63, image 3 of 3
    • Hold the back glass above the phone and align it with the frame.
    • Lay the glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
    Ask FixBot
  64. iPhone 16 Plus Microphone Replacement, Heat the back glass: step 64, image 1 of 3 iPhone 16 Plus Microphone Replacement, Heat the back glass: step 64, image 2 of 3 iPhone 16 Plus Microphone Replacement, Heat the back glass: step 64, image 3 of 3
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
    Ask FixBot
  65. iPhone 16 Plus Microphone Replacement, Press the back glass: step 65, image 1 of 3 iPhone 16 Plus Microphone Replacement, Press the back glass: step 65, image 2 of 3 iPhone 16 Plus Microphone Replacement, Press the back glass: step 65, image 3 of 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Ask FixBot
  66. iPhone 16 Plus Microphone Replacement: step 66, image 1 of 2 iPhone 16 Plus Microphone Replacement: step 66, image 2 of 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Ask FixBot
  67. iPhone 16 Plus Microphone Replacement: step 67, image 1 of 3 iPhone 16 Plus Microphone Replacement: step 67, image 2 of 3 iPhone 16 Plus Microphone Replacement: step 67, image 3 of 3
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Ask FixBot
  68. iPhone 16 Plus Microphone Replacement: step 68, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
  69. iPhone 16 Plus Microphone Replacement, Install the pentalobe screws: step 69, image 1 of 2 iPhone 16 Plus Microphone Replacement, Install the pentalobe screws: step 69, image 2 of 2
    • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Plus Answers community for help.
Nick Schultz
56,893 Reputation
321 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 1,314
