iPhone 15 Plus Screen Replacement
  1. iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Ask FixBot
  2. iPhone 15 Plus Screen Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Plus Screen Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 15 Plus Screen Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 15 Plus Screen Replacement, Remove the pentalobe screws: step 4, image 1 of 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Ask FixBot
  5. iPhone 15 Plus Screen Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 15 Plus Screen Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 15 Plus Screen Replacement, Screen information: step 7, image 1 of 2 iPhone 15 Plus Screen Replacement, Screen information: step 7, image 2 of 2
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Ask FixBot
  8. iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  9. iPhone 15 Plus Screen Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the screen until it's hot to the touch.
    Ask FixBot
  10. iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: step 10, image 1 of 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: step 10, image 2 of 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: step 10, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Insert a second opening pick to the right of the first one.
    • Slide the pick along the right edge of the screen to release the clips and separate the adhesive securing it.
    Ask FixBot
  11. iPhone 15 Plus Screen Replacement, Heat the top edge: step 11, image 1 of 1
    • Heat the top edge of the screen until it's hot to the touch.
    Ask FixBot
  12. iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: step 12, image 1 of 2 iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: step 12, image 2 of 2
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner and slide it along the top edge to release the two clips and adhesive securing it.
    Ask FixBot
  13. iPhone 15 Plus Screen Replacement, Heat the left edge: step 13, image 1 of 1
    • Heat the left edge of the screen until it's hot to the touch.
    Ask FixBot
  14. iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: step 14, image 1 of 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: step 14, image 2 of 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: step 14, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
    Ask FixBot
  15. iPhone 15 Plus Screen Replacement, Swing open the screen: step 15, image 1 of 2 iPhone 15 Plus Screen Replacement, Swing open the screen: step 15, image 2 of 2
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
    Ask FixBot
  16. iPhone 15 Plus Screen Replacement, Unfasten the front sensor connector cover: step 16, image 1 of 1
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
    Ask FixBot
  17. iPhone 15 Plus Screen Replacement, Remove the cover: step 17, image 1 of 3 iPhone 15 Plus Screen Replacement, Remove the cover: step 17, image 2 of 3 iPhone 15 Plus Screen Replacement, Remove the cover: step 17, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    Ask FixBot
  18. iPhone 15 Plus Screen Replacement, Disconnect the front sensor: step 18, image 1 of 2 iPhone 15 Plus Screen Replacement, Disconnect the front sensor: step 18, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
    Ask FixBot
  19. iPhone 15 Plus Screen Replacement, Unfasten the screen connector cover: step 19, image 1 of 1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
    Ask FixBot
  20. iPhone 15 Plus Screen Replacement, Remove the cover: step 20, image 1 of 3 iPhone 15 Plus Screen Replacement, Remove the cover: step 20, image 2 of 3 iPhone 15 Plus Screen Replacement, Remove the cover: step 20, image 3 of 3
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
    Ask FixBot
  21. iPhone 15 Plus Screen Replacement, Disconnect the screen: step 21, image 1 of 2 iPhone 15 Plus Screen Replacement, Disconnect the screen: step 21, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
    Ask FixBot
  22. iPhone 15 Plus Screen Replacement, Remove the screen: step 22, image 1 of 2 iPhone 15 Plus Screen Replacement, Remove the screen: step 22, image 2 of 2
    • Remove the screen.
    Ask FixBot
  23. iPhone 15 Plus Screen Replacement, End of disassembly: step 23, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • Reassembly photos are of the iPhone 15 non‑Plus. It may look a little different, but the procedure is correct.
    Ask FixBot
  24. iPhone 15 Plus Screen Replacement, Remove the screen adhesive: step 24, image 1 of 3 iPhone 15 Plus Screen Replacement, Remove the screen adhesive: step 24, image 2 of 3 iPhone 15 Plus Screen Replacement, Remove the screen adhesive: step 24, image 3 of 3
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the screen, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    Ask FixBot
  25. iPhone 15 Plus Screen Replacement: step 25, image 1 of 3 iPhone 15 Plus Screen Replacement: step 25, image 2 of 3 iPhone 15 Plus Screen Replacement: step 25, image 3 of 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  26. iPhone 15 Plus Screen Replacement, Ambient light sensor information: step 26, image 1 of 1
    • The ambient light sensor is located behind the screen, directly beneath the cut‑out for the Face ID sensors.
    • Check if the replacement screen comes with one installed. If it does, skip to this step.
    Ask FixBot
  27. iPhone 15 Plus Screen Replacement, Remove the ambient light sensor bracket: step 27, image 1 of 2 iPhone 15 Plus Screen Replacement, Remove the ambient light sensor bracket: step 27, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
    Ask FixBot
  28. iPhone 15 Plus Screen Replacement: step 28, image 1 of 2 iPhone 15 Plus Screen Replacement: step 28, image 2 of 2
    • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
    Ask FixBot
  29. iPhone 15 Plus Screen Replacement, Heat the ambient light sensor: step 29, image 1 of 1
    Ask FixBot
  30. iPhone 15 Plus Screen Replacement, Pry up the ambient light sensor: step 30, image 1 of 2 iPhone 15 Plus Screen Replacement, Pry up the ambient light sensor: step 30, image 2 of 2
    • Use a spudger to pry up the ambient light sensor.
    Ask FixBot
  31. iPhone 15 Plus Screen Replacement, Peel up the ambient light sensor cable: step 31, image 1 of 2 iPhone 15 Plus Screen Replacement, Peel up the ambient light sensor cable: step 31, image 2 of 2
    • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving towards to the opposite corner until it's free from the screen.
    • If the adhesive doesn't peel up easily, apply more heat.
    Ask FixBot
  32. iPhone 15 Plus Screen Replacement, Remove the ambient light sensor: step 32, image 1 of 1
    • Use a pair of tweezers to lift the ambient light sensor off of the screen.
    Ask FixBot
  33. iPhone 15 Plus Screen Replacement, Prepare the ambient light sensor: step 33, image 1 of 2 iPhone 15 Plus Screen Replacement, Prepare the ambient light sensor: step 33, image 2 of 2
    Tesa 61395 Tape
    $2.95
    Buy
    • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised white rectangle.
    • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along its bottom border.
    Ask FixBot
  34. iPhone 15 Plus Screen Replacement, Place the ambient light sensor: step 34, image 1 of 2 iPhone 15 Plus Screen Replacement, Place the ambient light sensor: step 34, image 2 of 2
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to press the ambient light sensor into its recess.
    Ask FixBot
  35. iPhone 15 Plus Screen Replacement, Warm the ambient light sensor: step 35, image 1 of 1
    • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable. It only needs to be warm—not hot.
    Ask FixBot
  36. iPhone 15 Plus Screen Replacement, Press the ambient light sensor: step 36, image 1 of 3 iPhone 15 Plus Screen Replacement, Press the ambient light sensor: step 36, image 2 of 3 iPhone 15 Plus Screen Replacement, Press the ambient light sensor: step 36, image 3 of 3
    Tesa 61395 Tape
    $2.95
    Buy
    • Use your finger to press down the ambient light sensor cable.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
    Ask FixBot
  37. iPhone 15 Plus Screen Replacement, Install the ambient light sensor bracket: step 37, image 1 of 3 iPhone 15 Plus Screen Replacement, Install the ambient light sensor bracket: step 37, image 2 of 3 iPhone 15 Plus Screen Replacement, Install the ambient light sensor bracket: step 37, image 3 of 3
    • Use tweezers or your fingers to hook the ambient light sensor bracket over the back of the sensor and set it into place.
    Ask FixBot
  38. iPhone 15 Plus Screen Replacement: step 38, image 1 of 2 iPhone 15 Plus Screen Replacement: step 38, image 2 of 2
    • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
    Ask FixBot
  39. iPhone 15 Plus Screen Replacement, Orient the adhesive: step 39, image 1 of 3 iPhone 15 Plus Screen Replacement, Orient the adhesive: step 39, image 2 of 3 iPhone 15 Plus Screen Replacement, Orient the adhesive: step 39, image 3 of 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Ask FixBot
  40. iPhone 15 Plus Screen Replacement, Apply the adhesive: step 40, image 1 of 3 iPhone 15 Plus Screen Replacement, Apply the adhesive: step 40, image 2 of 3 iPhone 15 Plus Screen Replacement, Apply the adhesive: step 40, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    Ask FixBot
  41. iPhone 15 Plus Screen Replacement: step 41, image 1 of 3 iPhone 15 Plus Screen Replacement: step 41, image 2 of 3 iPhone 15 Plus Screen Replacement: step 41, image 3 of 3
    • When the adhesive is aligned, use the flat end of a spudger, or your finger, to press it down firmly along the bottom edge.
    Ask FixBot
  42. iPhone 15 Plus Screen Replacement: step 42, image 1 of 3 iPhone 15 Plus Screen Replacement: step 42, image 2 of 3 iPhone 15 Plus Screen Replacement: step 42, image 3 of 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Ask FixBot
  43. iPhone 15 Plus Screen Replacement, Press the adhesive into place: step 43, image 1 of 3 iPhone 15 Plus Screen Replacement, Press the adhesive into place: step 43, image 2 of 3 iPhone 15 Plus Screen Replacement, Press the adhesive into place: step 43, image 3 of 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Ask FixBot
  44. iPhone 15 Plus Screen Replacement, Remove the top liner: step 44, image 1 of 2 iPhone 15 Plus Screen Replacement, Remove the top liner: step 44, image 2 of 2
    • Insert the point of a spudger under the top liner's hole at the bottom of the frame.
    • Pry up to separate the liner from the frame—enough to grip it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
    Ask FixBot
  45. iPhone 15 Plus Screen Replacement: step 45, image 1 of 3 iPhone 15 Plus Screen Replacement: step 45, image 2 of 3 iPhone 15 Plus Screen Replacement: step 45, image 3 of 3
    • Peel back the top liner and remove it.
    Ask FixBot
  46. iPhone 15 Plus Screen Replacement, Prop up the screen: step 46, image 1 of 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Ask FixBot
  47. iPhone 15 Plus Screen Replacement, Connect the screen: step 47, image 1 of 2 iPhone 15 Plus Screen Replacement, Connect the screen: step 47, image 2 of 2
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
    Ask FixBot
  48. iPhone 15 Plus Screen Replacement: step 48, image 1 of 3 iPhone 15 Plus Screen Replacement: step 48, image 2 of 3 iPhone 15 Plus Screen Replacement: step 48, image 3 of 3
    • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
    Ask FixBot
  49. iPhone 15 Plus Screen Replacement: step 49, image 1 of 3 iPhone 15 Plus Screen Replacement: step 49, image 2 of 3 iPhone 15 Plus Screen Replacement: step 49, image 3 of 3
    • Insert the front sensor connector cover into its slot in the frame at a 90‑degree angle vertically.
    • Lay the cover over the press connector.
    Ask FixBot
  50. iPhone 15 Plus Screen Replacement, Install the cover screws: step 50, image 1 of 2 iPhone 15 Plus Screen Replacement, Install the cover screws: step 50, image 2 of 2
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Ask FixBot
  51. iPhone 15 Plus Screen Replacement, Remove the final adhesive liners: step 51, image 1 of 2 iPhone 15 Plus Screen Replacement, Remove the final adhesive liners: step 51, image 2 of 2
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a spudger, or your fingers, to separate the pull tabs at the bottom right corner of the frame.
    Ask FixBot
  52. iPhone 15 Plus Screen Replacement: step 52, image 1 of 3 iPhone 15 Plus Screen Replacement: step 52, image 2 of 3 iPhone 15 Plus Screen Replacement: step 52, image 3 of 3
    • Remove the narrow liner covering the adhesive along the right and top edges of the frame.
    Ask FixBot
  53. iPhone 15 Plus Screen Replacement: step 53, image 1 of 3 iPhone 15 Plus Screen Replacement: step 53, image 2 of 3 iPhone 15 Plus Screen Replacement: step 53, image 3 of 3
    • Remove the liner along the bottom edge of the frame.
    Ask FixBot
  54. iPhone 15 Plus Screen Replacement: step 54, image 1 of 3 iPhone 15 Plus Screen Replacement: step 54, image 2 of 3 iPhone 15 Plus Screen Replacement: step 54, image 3 of 3
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
    Ask FixBot
  55. iPhone 15 Plus Screen Replacement, Place the screen: step 55, image 1 of 3 iPhone 15 Plus Screen Replacement, Place the screen: step 55, image 2 of 3 iPhone 15 Plus Screen Replacement, Place the screen: step 55, image 3 of 3
    • Lay the screen straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the screen to engage all clips.
    Ask FixBot
  56. iPhone 15 Plus Screen Replacement, Heat the screen: step 56, image 1 of 2 iPhone 15 Plus Screen Replacement, Heat the screen: step 56, image 2 of 2
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    Ask FixBot
  57. iPhone 15 Plus Screen Replacement, Press the screen: step 57, image 1 of 3 iPhone 15 Plus Screen Replacement, Press the screen: step 57, image 2 of 3 iPhone 15 Plus Screen Replacement, Press the screen: step 57, image 3 of 3
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Ask FixBot
  58. iPhone 15 Plus Screen Replacement: step 58, image 1 of 2 iPhone 15 Plus Screen Replacement: step 58, image 2 of 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Ask FixBot
  59. iPhone 15 Plus Screen Replacement: step 59, image 1 of 3 iPhone 15 Plus Screen Replacement: step 59, image 2 of 3 iPhone 15 Plus Screen Replacement: step 59, image 3 of 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
    Ask FixBot
  60. iPhone 15 Plus Screen Replacement: step 60, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
  61. iPhone 15 Plus Screen Replacement, Install the pentalobe screws: step 61, image 1 of 2 iPhone 15 Plus Screen Replacement, Install the pentalobe screws: step 61, image 2 of 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
    Ask FixBot
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
7 other people completed this guide.
Clay Eickemeyer
104,117 Reputation
476 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
17,861 Guides authored
4 Guide Comments
No link for screen?
Josh Clayman - Reply Share
Battery still plugged in? You would need to take the back glass also
Smarterthanyou - Reply Share
You actually won’t need to unplug the battery before hand. Just attach the new screen, and if the phone is still “on” do a soft reset, and the screen will start normally
Rob Preston - Reply Share
Incomplete guide. No instructions for reassembly. Part ordered directly from ifixit is different than part removed. Unsure how to proceed. Refund requested
Blake Rhodenizer - Reply Share
Past 24 Hours: 44
Past 7 Days: 236
Past 30 Days: 1,073
All Time: 23,045
