Introduction
iPhone 5 lost its buzz? Use this guide to get it back with a new vibrator.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Tool used on this step:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following two screws securing the metal battery connector bracket to the logic board:
One 1.8 mm Phillips screw
One 1.6 mm Phillips screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
Two 1.2 mm Phillips screws
Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
Front-facing camera and sensor cable
LCD cable
Digitizer cable
Remove the front panel assembly from the rear case.
Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
Wait about one minute for the alcohol solution to weaken the adhesive. Use an opening tool to gently lift the battery by its edge.
Do not pry at the top portion of the battery, you risk severing the volume control cables.
Remove the battery.
Adhere the battery, disconnect it, and continue reassembling your device.
Remove two screws securing the vibrator bracket to the rear case:
Single 2.3 mm Phillips screw
Single 1.7 mm Phillips screw
42 other people completed this guide.
3 Comments
Hi, I've repaired my Iphone 5 from an other repair. After the repair the vibrator didn't work anymore, all the settings were correct. So I thought the motor was broken and had a spare one from another repaired phone. I replaced it and still nothing happened.
For my last resort I tried to reset all settings and suddenly it started working again!
So before you try to take your phone apart please try this method first and save a lot of time with this method.
-edit
found the setting that was causing the trouble.
1. go to settings
2. scroll to General
3. click the accesibility tab
4. scroll down to the 4th bar
5. there is an option called vibrate
6. turn this option off
Coulnd't find any answers of this on forums, so I posted it here.
Also I hadn't removed the battery to replace the vibrator, just buy a good screwdriver and it will work.
After replacing my battery with the I fix it my phone has been acting very strange. The vibrator and the volumes buttons aren't working anymore. Neither is my home button why is this?
