Samsung Galaxy S7 Edge Display Assembly Replacement
  1. Samsung Galaxy S7 Edge Display Assembly Replacement, SIM Card Tray: step 1, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement, SIM Card Tray: step 1, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement, SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM card opening tool, SIM eject bit, or a paperclip into the small hole on the top edge of the phone.
    • There are two holes on the top edge. The correct hole is within a long rectangular cutout.
    • Press in the opening tool to eject the tray.
    • Remove the SIM/SD card combo tray from the phone.
  2. Samsung Galaxy S7 Edge Display Assembly Replacement, Rear Glass: step 2, image 1 of 1
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Heat an iOpener and apply it to a long edge of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy S7 Edge Display Assembly Replacement: step 3, image 1 of 1
    • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not adhere well on the curved portion of the glass.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup and insert an opening pick under the rear glass.
    • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  4. Samsung Galaxy S7 Edge Display Assembly Replacement: step 4, image 1 of 1
    • Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  5. Samsung Galaxy S7 Edge Display Assembly Replacement: step 5, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 5, image 2 of 2
    • Slide the opening pick up along the side of the phone, separating the adhesive.
    • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  6. Samsung Galaxy S7 Edge Display Assembly Replacement: step 6, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 6, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 6, image 3 of 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy S7 Edge Display Assembly Replacement: step 7, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 7, image 2 of 2
    • Lift the glass and remove it from the phone.
  8. Samsung Galaxy S7 Edge Display Assembly Replacement: step 8, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 8, image 2 of 2
    • To install a new back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old back cover, or using a back cover without adhesive pre-installed, follow this guide.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  9. Samsung Galaxy S7 Edge Display Assembly Replacement, Loudspeaker Assembly: step 9, image 1 of 1
    • Remove the twelve 3.5 mm Phillips screws.
  10. Samsung Galaxy S7 Edge Display Assembly Replacement: step 10, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 10, image 2 of 2
    • Use the small notch on the lower left of the upper antenna to pry it out of the phone.
    • Remove the upper antenna.
  11. Samsung Galaxy S7 Edge Display Assembly Replacement: step 11, image 1 of 1
    • Lift and remove the wireless charging coil from the phone.
  12. Samsung Galaxy S7 Edge Display Assembly Replacement: step 12, image 1 of 1
    • Lift and remove the loudspeaker from the phone.
  13. Samsung Galaxy S7 Edge Display Assembly Replacement, Battery Disconnect: step 13, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement, Battery Disconnect: step 13, image 2 of 2
    • Use the flat end of a spudger to disconnect the battery connector.
  14. Samsung Galaxy S7 Edge Display Assembly Replacement, Display Assembly: step 14, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement, Display Assembly: step 14, image 2 of 2
    • Use the flat end of a spudger to disconnect the display cable.
  15. Samsung Galaxy S7 Edge Display Assembly Replacement: step 15, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 15, image 2 of 2
    • Use the pointed end of a spudger to disconnect the power button cable.
  16. Samsung Galaxy S7 Edge Display Assembly Replacement: step 16, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 16, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 16, image 3 of 3
    • Use the pointed end of a spudger to disconnect the red and white antenna cables.
  17. Samsung Galaxy S7 Edge Display Assembly Replacement: step 17, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 17, image 2 of 2
    • Use the flat end of a spudger to disconnect the home button connector.
  18. Samsung Galaxy S7 Edge Display Assembly Replacement: step 18, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 18, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 18, image 3 of 3
    • Use the pointed end of a spudger to disconnect the front-facing sensory array cables.
  19. Samsung Galaxy S7 Edge Display Assembly Replacement: step 19, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 19, image 2 of 2
    • Use a pointed end of a spudger to disconnect the volume button cable.
  20. Samsung Galaxy S7 Edge Display Assembly Replacement: step 20, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 20, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 20, image 3 of 3
    • Do not lift the motherboard out all the way; it is still connected to the daughter board by a cable.
    • Use the flat end of a spudger to gently pry the motherboard up.
    • Grip the edges of the motherboard and hinge it up slowly, using the spudger to push cables out of its path.
  21. Samsung Galaxy S7 Edge Display Assembly Replacement: step 21, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 21, image 2 of 2
    • Use the flat end of the spudger to disconnect the daughterboard ribbon cable from the underside of the motherboard.
    • Remove the motherboard.
  22. Samsung Galaxy S7 Edge Display Assembly Replacement: step 22, image 1 of 1
    • Heat an iOpener and apply it to top edge of the display.
    • While you are waiting for the adhesive to soften, read the next step to get an idea of where to pry.
  23. Samsung Galaxy S7 Edge Display Assembly Replacement: step 23, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 23, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 23, image 3 of 3
    • The display assembly edges are secured by strips of very strong foam adhesive.
    • Strong double-sided tape covers the entire copper surface.
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • The capacitive buttons are adhered to the display and are very easy to tear. They must be reused for the repair.
    • While the OLED panel and display cable will be replaced with the new display, the capacitive buttons must be reused, so take extreme care not to damage them.
    • If you do break either of the capacitive buttons or ribbon cables, you can replace the daughterboard assembly, which includes new capacitive buttons.
  24. Samsung Galaxy S7 Edge Display Assembly Replacement: step 24, image 1 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 24, image 2 of 3 Samsung Galaxy S7 Edge Display Assembly Replacement: step 24, image 3 of 3
    • Once the edge is warm, apply a suction cup as close to the top edge as possible without overlapping the speaker grill.
    • If your display is badly cracked, lay down a layer of tape on the display and try lifting the display with strong tape.
    • Lift on the suction cup to create a small gap underneath the top edge of the display.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • Insert an opening pick into the gap. Take care not to insert it more than 0.25 inches in.
    • Due to the strong adhesive, this may require several attempts. Follow the iOpener heating instructions and repeat the heat-suction-lift procedure until you can get a pick in place.
  25. Samsung Galaxy S7 Edge Display Assembly Replacement: step 25, image 1 of 1
    • With the opening pick in place, apply a heated iOpener to the top edge once more in order to soften the adhesive.
  26. Samsung Galaxy S7 Edge Display Assembly Replacement: step 26, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 26, image 2 of 2
    • Slide the opening pick along the top edge of the display taking care not to push deeper than 0.25 inches.
    • Inserting the pick too far may damage the front-facing camera or earpiece speaker.
    • Leave the pick on the top edge the prevent the adhesive from resealing.
  27. Samsung Galaxy S7 Edge Display Assembly Replacement: step 27, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 27, image 2 of 2
    • Repeat the previous heating and cutting procedure for the long edges of the phone. Do not cut the bottom edge yet.
    • There are large areas of adhesive holding the display to the frame. Work slowly and methodically to slice through as much of the adhesive as possible.
    • Leave an opening pick on each edge as you continue to the next to prevent the adhesive from resealing.
    • The display cable is located just above the midpoint on the right side, and may interfere with your pick if you pry too deeply.
  28. Samsung Galaxy S7 Edge Display Assembly Replacement: step 28, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 28, image 2 of 2
    • Insert an opening pick in the bottom right corner.
    • Push the pick in slowly. Try to leverage the pick's cutting edge upward so that it slides against the back of the display.
    • This allows the pick to slice between the display and the capacitive button without damaging the button cable.
    • Once the pick has cut through the adhesive in the right corner, leave it in place to prevent the adhesive from resealing.
  29. Samsung Galaxy S7 Edge Display Assembly Replacement: step 29, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 29, image 2 of 2
    • Insert an opening pick in the bottom left corner.
    • Once the pick has cut through the adhesive in the left corner, leave it in place to prevent the adhesive from resealing.
  30. Samsung Galaxy S7 Edge Display Assembly Replacement: step 30, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 30, image 2 of 2
    • Use the opening picks to slice through adhesive around the home button and any other remaining adhesive.
    • Open the phone slightly, starting at the edge opposite the display cable.
    • Do not remove the display assembly. There is a display cable threaded through the midframe that is connected to the display.
  31. Samsung Galaxy S7 Edge Display Assembly Replacement: step 31, image 1 of 2 Samsung Galaxy S7 Edge Display Assembly Replacement: step 31, image 2 of 2
    • Lift the display assembly away from the midframe, carefully threading the display cable through the hole in the midframe.
    • Remove the display assembly.
  32. Samsung Galaxy S7 Edge Display Assembly Replacement: step 32, image 1 of 1
    • Follow this link for a detailed display adhesive application guide.
    • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
    • This helps remove any remaining adhesive residue and preps the surface for the new display.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
127 other people completed this guide.
Arthur Shi
252,842 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
38 Comments
Excellent guide, really enjoyed following the instructions. A job well done :-D
Craig Naidoo - Reply
How do you get the glass backing off without it shattering at all?
Simeon - Reply
There is no fool proof method. Apply liberal amounts of heat. Be careful when slicing near the corners. If your back has micro-fractures already, chances are your back will crack along the fracture.
Arthur Shi -
No matter how long I try to heat the back panel with an iOpener, I cannot seem to get the glue warm enough… Any advice on how to better unglue this thing?
Jérémie Corbier - Reply
Hi Jérémie,
The glue is pretty strong on this phone. You can try using a heat gun if you have one, or a hair dryer. You can also try the bottom edge instead of the long edge- sometimes the glue is not as strong there.
Arthur Shi -
Past 24 Hours: 7
Past 7 Days: 65
Past 30 Days: 325
All Time: 146,606
