Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Supplies
  • Open cell foam, self-adhesive, 1.5 mm thick: For light seals and mirror bumpers
  • Isopropyl alcohol: General cleaning
  • Cotton buds: General cleaning
  • Contact cement: Adhesive for attaching leatherette
  • Molybdenum grease: Lubrication for mechanical latching points
Camera Overview
The Super Program was Pentax's first camera with a Program exposure mode, meaning that it could select both the shutter speed and aperture setting when shooting with automatic exposure. It has a similar overall structure to the ME Super, but has some important differences.
The ME Super has a mechanical shutter release, allowing it to shoot with at least one speed when it doesn't have power. However, the Super Program uses a solenoid for the mirror release, meaning it cannot trigger the shutter without batteries. The mirror can be released manually in order to check the mechanical functionality after removing the bottom plate (see right). The Super Program also requires an additional mechanism to control the aperture in Program and Shutter Priority modes, which is located on the back of the lens board. This is where the mechanical self-timer was located on the ME Super, and that has consequently been replaced by an electronic self-timer.
The overall construction of the two cameras is quite similar, in terms of the major subassemblies. But the Super Program does have a more extensive flex PCB and requires more soldering to separate the electronics from the other mechanisms. Aside from that, disassembly and repair are quite similar.
Production Variation
At some point in its production run, Pentax implemented a significant design change to the electronics of the Super Program. The main flex PCB was redesigned, removing many of the hand-soldered connections in favor of a single screw-down connector. The easiest way to identify early production models from late production models is by looking at the electronics on top of the prism. Early models have an additional large IC while late models have a much more streamlined layout.
In terms of disassembly, the biggest difference will be found under the shutter release assembly. Early models have several hand soldered wires connecting the main PCB to the front lens board while late models have a simple flex connection. In the disassembly guides, some steps while have pictures of both production variations to document the different connections. Follow the instructions that best match your camera and take additional pictures where necessary.
Common Problems
The most common failures for the Pentax Super Program are a stuck reflex mirror or an advance lever that winds continuously (aka, "infinite wind"). Both have the same root cause, which are degraded rubber dampers in the mirror box mechanism. The failure can usually be repaired by cleaning out the old material (see the Mirror Box Disassembly guide.
Various electrical issues are somewhat common and are often caused by corroded battery contacts or internal wiring, which is repairable. There are also two solenoids inside the camera, one that releases the mirror and one that controls the aperture, which can fail and cause issues.
If you are already performing significant disassembly of the camera for a repair, consider doing a more complete overhaul of the camera to reduce the chance of future issues. The following service will address the most common failure points of the Super Program.
  • Mirror box mechanism: Remove old degraded rubber bumpers and clean all affected components.
  • Shutter block: Remove old degraded rubber bumpers and clean curtain pivots.
  • Light seals: Remove and replace old foam light/dust seals.
Lubrication
In general, cameras do not require lubrication to function. They should be able to operate normally without oil or grease. Consequently, if a camera is not functioning, adding lubrication is not the solution. But there are some areas where adding proper lubrication will improve performance or reduce wear. Whenever possible, use the service manual for your specific camera model to identify critical points. When that isn't available, some general guidelines can be used to determine what kind of lubrication a mechanism might benefit from.
Generic levers and gears: No lubrication. Most of the mechanisms in a camera shouldn't be lubricated. A latch moving back and forth or an idler gear spinning do not require lubrication. If such a mechanism is sticking, it needs to be disassembled and cleaned. Lubrication is not free and comes with drawbacks, mainly that it holds dirt and grime. If an interface is lubricated, it needs periodic cleaning and re-lubrication to maintain. So the first rule is, unless it serves a specific purpose, don't use lubrication.
Fast moving shutter mechanisms: A lightweight synthetic oil (e.g. NyOil). These are gears and shafts that spin or move rapidly when the shutter is fired. Some cameras require oiling the interfaces to get more consistent shutter speeds, but the shutter in the Super Program runs dry, without any oil. When servicing the shutter, cleaning and reassembly is all that is required.
Latching points: A heavy weight lithium grease with molybdenum disulfide (NLGI 3-4). There are a lot of metal-to-metal interfaces where mechanisms interact with each other. Sliding, hooking, latching, etc. These are often high friction interfaces and if left unlubricated can wear over time. Choose a grease that is very sticky and will stay in place on the applied surfaces. The moly additive helps further reduce wear at the surface of the materials.
High load interfaces: A medium weight lithium grease with molybdenum disulfide (NLGI 2-3). The film advance mechanism would fit into this category where it's common practice to grease the shaft of main wind gear, providing a much smoother feel and, more importantly, preventing wear.
Knob and dial detents: A medium weight lithium grease (NLGI 1-3). Shutter speed dials, aperture rings, etc. Most of the time the clicks will be provided by some kind of spring loaded feature jumping between grooves. Picking the best lubrication for these interfaces can require some trial and error as getting the proper feel is highly dependent on the geometry of the detents, the force of the spring, and the types of interfacing materials.
Troubleshooting
See the Pentax Super Program Troubleshooting page.
Pentax Super Program Exploded Illustration
Pentax Super Program Camera Manual
Sam Gustafson
14,868 Reputation
78 Guides authored
Past 24 Hours: 13
Past 7 Days: 53
Past 30 Days: 208
All Time: 1,992
