Pentax Super Program Shutter Timing Adjustment
View statistics:
Past 24 Hours:
16
Past 7 Days:
32
Past 30 Days:
113
All Time:
434
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The electronic speeds on the Super Program can be adjusted by connecting the shutter to the front block before it is reinstalled to into the camera. Curtain speeds should only be adjusted with a three sensor shutter tester that can accurately measure the travel times. The curtain delay can be adjusted to a reasonable degree with a single sensor tester.
    1. Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: step 1, image 1 of 2 Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: step 1, image 2 of 2
      • The shutter should be installed in the camera chassis.
      • Solder jumper wires to the red, brown and white shutter controls signals.
      • Solder a jumper wire to the positive battery terminal.
      • Solder a jumper wire to the ground connection.
      • Install the bottom cover and batteries.
      Ask FixBot
    2. Pentax Super Program Shutter Timing Adjustment, Prepare the front block: step 2, image 1 of 3 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: step 2, image 2 of 3 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: step 2, image 3 of 3
      • Solder the jumper wires from the shutter control wires.
      • Red wire connection.
      • White wire connection.
      • Brown wire connection.
      • Solder the jumper wire from positive battery.
      • Connect the ground wire to the camera chassis.
      • Connect the shutter release plate to the camera chassis (ground).
      Ask FixBot
    3. Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: step 3, image 1 of 2 Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: step 3, image 2 of 2
      • Turn the mode dial to the 'M' position.
      • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
      • Adjust the shutter speed by grounding the contact posts for the shutter speed selector buttons.
      Ask FixBot
      • The camera has the necessary electrical connections to operate the shutter, but some of the mechanical actions have to be done manually.
      • Charge the mirror mechanism.
      • Charge the shutter.
      • Press the shutter release.
      • Push the opening curtain latch on the shutter.
      • Push the mirror return latch.
      Ask FixBot
    4. Pentax Super Program Shutter Timing Adjustment, Adjust curtain travel times: step 5, image 1 of 1
      • Measure curtain travel times with a shutter tester. If the shutter is far out of spec, it may be necessary to select a slower shutter speed to get a reading.
      • Adjust the lower gear for the opening curtain. Turn clockwise to decrease travel time and counter-clockwise to increase.
      • Adjust the upper gear for the closing curtain.
      • Both curtains should have a travel time of 5.6 ms over 22 mm. Incrementing the gears by one tooth changes the travel time by ~0.05 ms.
      Ask FixBot
    5. Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: step 6, image 1 of 2 Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: step 6, image 2 of 2
      • Set the shutter speed to 2000.
      • Adjust the eccentric post until the exposure time measures 0.5 ms.
      • The service manual gives an acceptable range of 0.45 to 0.6 ms for the 1/2000 setting. Other speeds should be accurate at this point.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 32
Past 30 Days: 113
All Time: 434
