Shop the Holiday Gift Guide
Pentax Super Program Aperture Coupling Ring Disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
95
All Time:
371
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 2 - 3 hours
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
The aperture coupling tab can become sticky and sluggish over time. This can prevent the camera from reading the set aperture from the lens. Disassembling and cleaning the coupling ring will restore proper functionality. If the camera is disassembled for other unrelated issues, it's still a good idea to perform this cleaning to prevent future issues.
Tools
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: step 1, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: step 1, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: step 1, image 3 of 3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Ask FixBot
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mode dial: step 2, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mode dial: step 2, image 2 of 2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Ask FixBot
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: step 3, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: step 3, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: step 3, image 3 of 3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Ask FixBot
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: step 4, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: step 4, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: step 4, image 3 of 3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Ask FixBot
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: step 5, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: step 5, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: step 5, image 3 of 3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Ask FixBot
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove bottom cover: step 6, image 1 of 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Ask FixBot
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: step 7, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: step 7, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: step 7, image 3 of 3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Ask FixBot
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB with adjustment pots: step 8, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB with adjustment pots: step 8, image 2 of 2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Ask FixBot
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder motor drive connections: step 9, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder motor drive connections: step 9, image 2 of 2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Ask FixBot
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove tripod mount: step 10, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove tripod mount: step 10, image 2 of 2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Ask FixBot
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Detach ISO resistor assembly: step 11, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach ISO resistor assembly: step 11, image 2 of 2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Ask FixBot
    6. Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: step 12, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: step 12, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: step 12, image 3 of 3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Ask FixBot
    7. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder flash sync wires: step 13, image 1 of 1
      • Unsolder two gray wires.
      Ask FixBot
    8. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder shutter wires: step 14, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder shutter wires: step 14, image 2 of 2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Ask FixBot
    9. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: step 15, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: step 15, image 2 of 2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Ask FixBot
    10. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew front board: step 16, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew front board: step 16, image 2 of 2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Ask FixBot
    11. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror box and front board: step 17, image 1 of 1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Ask FixBot
    12. Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Front Block: step 18, image 1 of 1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Ask FixBot
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder Main PCB: step 19, image 1 of 1
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      Ask FixBot
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder lens mount connections (early production): step 20, image 1 of 1
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      Ask FixBot
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder aperture resistor: step 21, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder aperture resistor: step 21, image 2 of 2
      • Unsolder two yellow wires for the aperture resistor.
      Ask FixBot
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: step 22, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: step 22, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: step 22, image 3 of 3
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      Ask FixBot
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder front board connections (early production): step 23, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder front board connections (early production): step 23, image 2 of 2
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      Ask FixBot
    6. Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB connection (late production): step 24, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB connection (late production): step 24, image 2 of 2
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      Ask FixBot
    7. Pentax Super Program Aperture Coupling Ring Disassembly, Detach viewfinder LCD: step 25, image 1 of 1
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      Ask FixBot
    8. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: step 26, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: step 26, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: step 26, image 3 of 3
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      Ask FixBot
    9. Pentax Super Program Aperture Coupling Ring Disassembly, Remove main PCB: step 27, image 1 of 1
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      Ask FixBot
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Detach front flex PCB: step 28, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach front flex PCB: step 28, image 2 of 2
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      Ask FixBot
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove beeper: step 29, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove beeper: step 29, image 2 of 2
      • Remove one screw and retainer plate.
      • Remove beeper.
      Ask FixBot
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: step 30, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: step 30, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: step 30, image 3 of 3
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      Ask FixBot
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror box: step 31, image 1 of 1
      • Lift mirror box away from front lens board.
      Ask FixBot
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Mirror Box: step 32, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Mirror Box: step 32, image 2 of 2
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      Ask FixBot
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: step 33, image 1 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: step 33, image 2 of 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: step 33, image 3 of 3
      • Unsolder two yellow wires.
      • Remove two screws.
      • Clean resistive strip with isopropyl alcohol.
      Ask FixBot
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove depth of field preview lever: step 34, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove depth of field preview lever: step 34, image 2 of 2
      • Remove one pin head screw.
      • Remove coupling lever.
      • Remove bias spring.
      Ask FixBot
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Remove ring retainer plates: step 35, image 1 of 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove ring retainer plates: step 35, image 2 of 2
      • Remove two screws and retainer plate.
      • Remove loose spring.
      Ask FixBot
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture coupling ring: step 36, image 1 of 1
      • Gently lift out aperture coupling ring. It is still attached.
      • Unhook coil spring.
      Ask FixBot
      • Clean the aperture coupling ring and the track it sits in with isopropyl alcohol.
      • When assembled, the ring should rotate smoothly and quickly snap back to its home position.
      Ask FixBot
Author
with
Sam Gustafson
14,878 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 95
All Time: 371
