Pentax Super Program Shutter Charging Mechanism Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
36
Past 30 Days:
112
All Time:
420
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The charging mechanism is very robust and rarely needs to be disassembled for repair. It is recorded here mostly for reference. Still, it is sometimes necessary in order to replace broken parts in the film advance such as the sprocket shaft or the take-up spool.
The pictures in this guide were taken with the mirror box removed from the camera, but it is not necessary for the disassembly. It can be done with the mirror box still in place.
Tools
    1. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom cover: step 1, image 1 of 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Ask FixBot
    1. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release lever: step 2, image 1 of 1
      • Remove one screw.
      • Lift the release lever and bias spring from the post. Be careful as the spring positioning it is still under tension.
      • Installation Notes: Pay attention to the location of the bias spring during reassembly.
      Ask FixBot
    2. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove contact pin housing: step 3, image 1 of 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove contact pin housing: step 3, image 2 of 2
      • Work the plastic housing off of the left contact pin. The right contact pin will come off with the housing.
      • If desired, the contact and wire can be fully removed from the camera. Soften the contact adhesive with isopropyl alcohol then gently peel away.
      Ask FixBot
    3. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove motor drive coupling: step 4, image 1 of 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove motor drive coupling: step 4, image 2 of 2
      • Remove plastic cover.
      • Remove one screw.
      • The screw is usually quite difficult to remove as it is secured with threadlocker. Use heat (e.g. soldering iron) or a penetrating solvent to soften the threadlocker. Be careful not to strip it.
      Ask FixBot
    4. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging linkage: step 5, image 1 of 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging linkage: step 5, image 2 of 2
      • Remove one shoulder screw.
      • Remove two screws.
      • Tilt the left side of the linkage up, then lift it away from the chassis.
      • Installation Notes: Make sure that the tab on the advance lock lever sits forward (in camera) of this lever. When the mirror is charged, the lever should move rearward (in camera) allowing the advance lock to engage.
      Ask FixBot
    5. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove wind completion switch: step 6, image 1 of 1
      • Remove one screw.
      • Lift out wind completion switch. Be careful not to deform the contact legs
      • Installation Notes: The contact should be open when the advance lock is engaged (after winding) and closed when the advance lock is disengaged (before winding).
      Ask FixBot
    6. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: step 7, image 1 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: step 7, image 2 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: step 7, image 3 of 3
      • Remove one circlip.
      • Lift the lever off the post.
      • Remove the bias spring.
      Ask FixBot
    7. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: step 8, image 1 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: step 8, image 2 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: step 8, image 3 of 3
      • Unhook coil spring from ratchet pawl.
      • Lift off ratchet pawl and shim washer.
      • Remove brass bushing.
      • Lift off advance lever lock.
      • Remove bias spring.
      Ask FixBot
    8. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove ratchet plate: step 9, image 1 of 1
      • Remove ratchet plate.
      Ask FixBot
    9. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release switch: step 10, image 1 of 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release switch: step 10, image 2 of 2
      • Remove one screw.
      • Lift out switch assembly.
      • Remove isolator sheet.
      Ask FixBot
    10. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: step 11, image 1 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: step 11, image 2 of 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: step 11, image 3 of 3
      • Keep a finger on top of the winding spring to hold it in place.
      • Unhook the end of the winding spring from the retaining post.
      • Unwind the spring in a controlled manner to prevent shock and breaking.
      • Remove one shim washer.
      • Installation Notes: When coiled and hooked, the spring should not be in contact with any other parts of the camera body. 7-8 wraps is typical.
      Ask FixBot
    11. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging mechanism plate: step 12, image 1 of 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging mechanism plate: step 12, image 2 of 2
      • Remove one screw.
      • Remove one screw.
      • Remove one slotted retaining post.
      • Remove charging mechanism plate.
      • Remove one plastic washer.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 36
Past 30 Days: 112
All Time: 420
