Pentax Super Program Front Block Removal
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
71
All Time:
554
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Community-Contributed Guide
Tools
    1. Pentax Super Program Front Block Removal, Remove film advance lever: step 1, image 1 of 3 Pentax Super Program Front Block Removal, Remove film advance lever: step 1, image 2 of 3 Pentax Super Program Front Block Removal, Remove film advance lever: step 1, image 3 of 3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Ask FixBot
    2. Pentax Super Program Front Block Removal, Remove mode dial: step 2, image 1 of 2 Pentax Super Program Front Block Removal, Remove mode dial: step 2, image 2 of 2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Ask FixBot
    3. Pentax Super Program Front Block Removal, Remove exposure compensation dial: step 3, image 1 of 3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: step 3, image 2 of 3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: step 3, image 3 of 3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Ask FixBot
    4. Pentax Super Program Front Block Removal, Remove top cover screws: step 4, image 1 of 3 Pentax Super Program Front Block Removal, Remove top cover screws: step 4, image 2 of 3 Pentax Super Program Front Block Removal, Remove top cover screws: step 4, image 3 of 3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Ask FixBot
    5. Pentax Super Program Front Block Removal, Remove top cover: step 5, image 1 of 3 Pentax Super Program Front Block Removal, Remove top cover: step 5, image 2 of 3 Pentax Super Program Front Block Removal, Remove top cover: step 5, image 3 of 3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Ask FixBot
    1. Pentax Super Program Front Block Removal, Remove bottom cover: step 6, image 1 of 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Ask FixBot
    1. Pentax Super Program Front Block Removal, Remove front leatherette panels: step 7, image 1 of 3 Pentax Super Program Front Block Removal, Remove front leatherette panels: step 7, image 2 of 3 Pentax Super Program Front Block Removal, Remove front leatherette panels: step 7, image 3 of 3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Ask FixBot
    2. Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: step 8, image 1 of 2 Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: step 8, image 2 of 2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Ask FixBot
    3. Pentax Super Program Front Block Removal, Unsolder motor drive connections: step 9, image 1 of 2 Pentax Super Program Front Block Removal, Unsolder motor drive connections: step 9, image 2 of 2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Ask FixBot
    4. Pentax Super Program Front Block Removal, Remove tripod mount: step 10, image 1 of 2 Pentax Super Program Front Block Removal, Remove tripod mount: step 10, image 2 of 2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Ask FixBot
    5. Pentax Super Program Front Block Removal, Detach ISO resistor assembly: step 11, image 1 of 2 Pentax Super Program Front Block Removal, Detach ISO resistor assembly: step 11, image 2 of 2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Ask FixBot
    6. Pentax Super Program Front Block Removal, Detach mode dial unit: step 12, image 1 of 3 Pentax Super Program Front Block Removal, Detach mode dial unit: step 12, image 2 of 3 Pentax Super Program Front Block Removal, Detach mode dial unit: step 12, image 3 of 3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Ask FixBot
    7. Pentax Super Program Front Block Removal, Unsolder flash sync wires: step 13, image 1 of 1
      • Unsolder two gray wires.
      Ask FixBot
    8. Pentax Super Program Front Block Removal, Unsolder shutter wires: step 14, image 1 of 2 Pentax Super Program Front Block Removal, Unsolder shutter wires: step 14, image 2 of 2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Ask FixBot
    9. Pentax Super Program Front Block Removal, Unscrew mirror box: step 15, image 1 of 2 Pentax Super Program Front Block Removal, Unscrew mirror box: step 15, image 2 of 2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Ask FixBot
    10. Pentax Super Program Front Block Removal, Unscrew front board: step 16, image 1 of 2 Pentax Super Program Front Block Removal, Unscrew front board: step 16, image 2 of 2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Ask FixBot
    11. Pentax Super Program Front Block Removal, Remove mirror box and front board: step 17, image 1 of 1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Ask FixBot
    12. Pentax Super Program Front Block Removal, Installation Notes: Front Block: step 18, image 1 of 1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 71
All Time: 554
