Making A Keyboard Replacement Guide...
I am going to replace 4 keyboards on 4 MB Air Models. I have noticed there is actually no actual guide on how to do this. There are many steps involved so:
Question 1: Can I simply copy everything from an existing guide to use as a kind of template, and just add the missing steps creating a new guide?
Question 2: As this will cover all A1369 A1370 A1465 & A1466 models ONLY how or where to add the guide? As many other models where the process will be somewhat different or even not possible at all. Do I copy the guide to every model that it is applicable to (6x MacBook Air 11" models 2010-15 & 7x MacBook Air 13" models 2010-2017)?.
Question 3: 2013/14/15 13" models use the same guide for MacBook Air 13" Mid 2013 Logic Board Replacement / MacBook Air 13" Early 2014 Logic Board Replacement / MacBook Air 13" Early 2015 Logic Board Replacement, but 2017 does not have one added even though it is the exact same layouts. So, Q3 is how to copy a complete guide to add it there, thus completing the guides for that particular years model as imo it makes perfect sense to add it.
I am hoping @krisrodriguez can provide.an answer to all 3 questions, thanks in advance.
Guide
Difficulty:
Moderate
2 hours
Guide
Difficulty:
Difficult
50 minutes - 1 hour
Guide
Difficulty:
Moderate
1 - 2 hours
11 Comments
@livfe - These guide try of questions belong over in META
by DanJ
@danj I seem to be unable to leave a comment or answer anything there.... https://meta.ifixit.com/Answers/View/216... I iteid to post a comment and answer regaring this Q: https://www.batterybuy.ph/batteries-appl...
by livfe
@livfe - META is iFixit not the blog space. Issues with the store postings or how to create a guide is what should be posted there. URL's of other sites should be emailed to Kris as a possible source for the store. But you need to make it clear that's your intent. As it's out of context it was likely removed. Also you need to have some street cred to post URL's your rep points within META makes a difference as well.
by DanJ
@danj OK then prehaps you can assist and forward the links above as they may help ID the battery for that unit as they are available over here. Anyway back to topic at hand.... any suggestions?
by livfe
@livfe - Just email the store via this form contact it looks like the older email address is no more.
As far as creating a guide I would create a Technique guide similar to MacBook Air 13" Bluetooth/Wifi Antenae /Webcam /Display Cable/Hinge Replacement but here you'll need to note the series Intel based Vs M Series and do a different one for that. There are some MacBook Pro guides which you might want to emulate.
by DanJ
Show 6 more comments
