Model A1046 or A1095 / 1280x854 screen resolution
118 Questions View all
S-Video Port intermittent; probably forced/damaged
The machine was moved with the S-Video cable attached and likely pulled hard enough in the process that damage occurred. There was no gradual degradation of the connection/signal.
When very lightly touched, the signal goes from fine to "squiggly and darker" and back again. There seems to be more play to the physical connection than there was before.
-Am wondering if replacing the Logic Board is the only option for repair, if the jack/port is loose or broken free.
Thanks for your consideration!
Score -1
Add a comment
1 Answer
Chosen Solution
If you're enough skilled you could try to resolder the socket on the logic board but why don't you use a miniDVI to video adapter ($15 on ebay) ? It gives you an extra S-Video port and a composite video port.
Score 4
1 Comment:
Sound advise +
by
Add a comment
Add your answer
DerekTrost will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,062
