Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
Stribes, stuck in opening grey screen, after crash.
iMac Intel 24" EMC 2134 (model A1225)
I was online watching something, then my mac crashed got stuck and was repeating the same sound over and over. I switched the mac of the hard way, and when I turned it on again it had a weird pixel image and got stuck after the opening sound, logo and in the grey screen.
The screen was not normal, though.
I have been looking around on different sites (including this) and have tried the "alt+command+r+p"
and finally I ran first the small and then the big hardware test - the screen was still striped - but it came out clear.
When I restarted the computer again everything seemed to work perfectly normal. Apple came up with failure report that I did not save :( but sent in, and then when I went back to the same site where it crashed (Danish broadcasting - nothing obscure!) again - with weird pixels and frozen screen. When I restarted I was back to square one.
Now I am running the big hardware test again to see that once more can get it out its weird mode.
After this the machine crash again during a skype video call - no sound this time, and machine haven't come back since.
Score -1
5 Comments
I am of course wondering if anyone have an idea of what is going on, and how I can fixit.
Thank You
by
I completed the big test again, once more it came out with no errors found on the hardware, and opened normally again after. Now I am being very careful to use a different browser (crome instead of firefox), and I still hope someone out there have some idea of what the problem might be.
Thank You, and have a nice weekend
Kat
by
A description of the sound would be helpful - so would a description of "weird" pixel image. Sounds like a flash player update may be needed. Check that you are running the current version.
by
I am sorry, I tried to upload a bunch of pictures of the screen, when I made the post, I don't where are now.
I am afraid the machine crashed again, and now it get stuck in the gray screen.
I have ran the big hardware test a number of times, and it have every single time come out with a ok. But it does not miraculously bring my mac to live, like it did the first two times
I have run a pram many times
It will not boot from the cd, when I do I get a kernel panic
so did a /sbin/fsck -fy twice and when it tries to reboot it gets stuck at the grey screen again.
I managed to get in to the single user mode by command s not command v.
The sound when the original crash was like when a cd player get stuck and plays the same sound over and over.
The stribes (vertical lines) er there all the time, when I run the hardware test, on the grey screen ect, in the single user mode.
Anything else I can do ?
by
I finally caved in, and send it to repair, the diagnose is the grafic card, and I agreed to get it changed.
by
Add a comment
1 Answer
Chosen Solution
Hook it up to an external monitor to isolate the problem and let us know your results. Boot from your system installation disk.
Score 2
1 Comment:
If I boot from the disk it goes into kernel panic every time. I am starting to suspect (from reading loads and loads of posts ect) it is the either a ram problem, or maybe the graphic or the video card. I am just wandering how normal it is that the hardware (expanded) does not pick that up ?
I will try to connect it to another screen and see what happens - and report back of course :)
by
Add a comment
Add your answer
katrine hel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,164
