Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 Questions View all
Changing parts from one to another?
Hello, I wonder about the possibilities to use parts from iBook 12 inch LCD on the models G3 and G4. Parts as hard drive, battery, keyboard and well there must be more parts changeable? I'm thinking about buying used parts!
Thankful for answers.
Dick.
Score 1
Add a comment
Chosen Solution
The LCD panel (But not the assembly) can be used in either computer, the batteries are also cross compatible, As is the hard drive, Keyboard, And charger. The logic boards, RAM, and Optical drives however, are not interchangeable.
Score 3
Add a comment
Most Helpful Answer
These parts can be swapped between the 12" iBook G3 and the G4
SCREEN ASSY:
- LCD panel
- front bezel (inscription wont match)
- hinges
- back cover (with Apple logo) color wont match
- inverter board
- display latch mechanism
NB: cables CAN'T be swapped (connectors wont match on logic board).
Other compatibles parts:
- keyboard (please read rj713 comment)
- battery (color wont match)
- AC adapter
- hard drive (IDE 2'5" HD)
- bottom case screws and rubber feet (color wont match)
All other parts are model specific and can't be swapped:
- ram
- optical drive
- top case
- airport card
- logic board
- heat sink
- internal metal frame
- DC in board
- HD & optical drive cables
- fan
- etc.
Score 4
3 Comments:
IIRC some keyboards won't work on some upper cases of the same model because of a groove in the top case is required for a proper fit. Ralph
by
thanks rj713, I edited my answer.
by
Thank you. Nice to know.
Dick.
by
Add a comment
Add your answer
Dick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 951
