Repair guides for the MacBook.
3787 Questions View all
Must I remove the Drive to get the Disc out?
I followed the guide to Step 13 and wondered if I could just remove the cover from the Optical Drive to get the CD out instead of removing the entire drive.
Even though it's a 2006 MacBook, the SuperDrive was replaced by the Depot in Oct. 2011 along with the logic board. They did not replace the tape and I'd rather not remove and reuse it if I don't have to.
When trying to start the MacBook, I do not even get the startup chime and I'd like to try to boot from the Install CD.
Score -1
Add a comment
Chosen Solution
This has come up many times in the past. Here is a link to one answer, Good luck.
How do I remove the CD's that are stuck in my MacBook?
Score 3
1 Comment:
Thanks for your help, but I guess my question wasn't well stated. I followed the guide in this Link:
MacBook Core Duo Optical Drive Replacement
Can I skip steps 14 through 30 and then go to the link you provided? In other words, can I remove the cover from the optical drive without removing the complete drive from my MacBook?
by
Add a comment
You'll have to remove the drive as there are screws on the sides that have to come out and you can't get to them with it still in the machine.
Score 3
Add a comment
Add your answer
Lauren Hutton will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 344
