Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
White screen after LCD replacement
I have a 2008 macbook A1181, MB881LL/A and I am getting a white screen. I swapped screens with a working lcd from a 2009 model and I am still getting a white screen. I tried different sticks of ram, its not that either.
Can some one tell me what I am doing wrong?
Score -1
Add a comment
Chosen Solution
The white screen most likely means your hard drive has gone bad. Try removing and replacing or removing it and see if it boots from your system installation disk. I just did this repair same repair an hour ago and the new hard drive did the trick.
Score 3
Add a comment
Have you rechecked throughly the data connection between LCD and Logic Board?
MacBook Core 2 Duo Display Data Cable Replacement
Score 2
Add a comment
I have, a tech suggested it might be the cable. I bought the laptop off ebay with the descrip saying that the screen shows white but when tried with another screen is displays and functions normally. The same for when hooked up to a VGA display.
Add a comment
Add your answer
craig fernandez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 553
