Power adaptor trouble in Ecuador...far away from apple store
I am far away from an apple store, (rural Ecuador...not that it matters), and my MacBook or the adaptor is failing. The power adaptor won't charge the battery and the macbook won't run off the adaptor. Battery at 11%. Shut down now. No green light.
Can I be sure the adaptor failed or could it be in the MacBook (DC board for example)? No other adaptor to available to test it. No other MacBook available either. Tried an SMC reset.
If I find a volt meter to see what the adaptor is putting out, and it is putting out the right nber of volts,it's I conclude that the MacBook is at fault?
Today there was some lightening in the sky. No problem with my iPhone charger.
Thanks
David
2 Comments
Not being a Mac person myself, I was just wondering if you have the availability of a multimeter, or just a simple voltmeter. Can you check your adapter and see what output, if any, you get? If your adapter is having the appropriate voltage etc, it might be a deeper problem like machead3 is suggesting.
by oldturkey03
Not sure if a manual would help you out but may be you can use it. Download it from here
by oldturkey03
