13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
No image or mirror image on display
I'm replacing a screen on a badly damaged MacBook, I replaced the LCD with a few different ones, and I keep getting a mirror image or no image at all, just backlit screen. I'm thinking I need a new cable from the screen to the board or an inverter cable... I wouldn't mind buying both to try it...but does anyone know of any other issues it could be? Cables are in securely...
Where can I buy these cables from? Ebay doesn't have it, iFixit doesn't have it... any suggestions?
Score 1
Add a comment
Chosen Solution
Check OWC
Score 1
Add a comment
Most Helpful Answer
You could try a local AASP, an Apple Store might or might not sell you the parts, technically they aren't supposed to. The cables are going to be 992- parts, which means the old part does not need to be returned for credit, which makes them a little easier to get than, say, a logic board.
Score 1
1 Comment:
I am an AASP... and apple is backordered on the parts... been so for 6 weeks now! thats why i am looking for another route to go... any other ideas?
by
Add a comment
Another place to try is LEM Swap. I've included the URL for you.
http://groups.google.com/group/lemswap
Another source is Laptopaid. Ralph
http://computers.shop.ebay.com/i.html?_n...
Score 1
Add a comment
you could try ebay, they might have parts, they would be cheaper there, but they might have them here, if not, there is one other website "welovemacs.com" i think it's called, but im not sure whether they have just parts, you should also be able to use a part from a 13" MacBook Pro, since it technicly is the same computer with the addition of an SD card slot. and "Pro" after "MacBook"
good luck, display parts can be a pain to find correct models, so make sure that you check before you buy anything!
Add a comment
Add your answer
Ptr702 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 6
All Time: 1,500
