Released by Samsung in March 2016. Model SM-G930.
425 Questions View all
Phone Not charging Post wireless charging coil replacement
So replaced the charge coil. And now battery does not charge. very possible I broke something or have a connector in the wrong spot. Phone does turn on but No charge at all. Any suggestions?
I added the 2 pictures below 1 of the back of the charging coil and one of the phone. I am thinking something is NOT making contact correctly. I did replace the battery at the same time so may be an issue there. But ordered a second coil to see if I messed up the first just looking for possibilities and hoping it is simply I do not have a good connection.
5 Comments:
Does anyone know if Wirelesss charging coil is required. For wired charging to work?
by
did u use the disassembly guide on this site?
to answer your question if the wireless charging is apart of that circuit, theres a chance that the corded option wont work as well. but dont quote me on that.
Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement
by
Am not finding anything useful, but I replaced a wireless charging coil in an android before and accidentally ripped the ribbon for the battery temp sensor. Would power up and run fine but refused to charge.
by
@logixal yes I followed that guide.
by
Ok so new recommendation. If it does not charge after putting together. Try a different charger. Before tearing it apart again.
by
Add a comment
1 Answer
Are you getting any kind of warning message when trying to charge the device? Samsung put a temperature sensor on the wireless charging coil and if the sensor isn’t working or not communicating with the device it will give a false temp reading and the device will think it’s too low to charge. There are contact pins at the top. Make sure they aren’t damaged or missing and make sure the screws in that area are in place.
1 Comment:
No warning message. Hope to get back to this problem this week. Fixing a broken valve spring on a van today.
by
Add a comment
Add your answer
GKJarhead will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 18
All Time: 252
