Phone Not charging Post wireless charging coil replacement
So replaced the charge coil. And now battery does not charge. very possible I broke something or have a connector in the wrong spot. Phone does turn on but No charge at all. Any suggestions?
I added the 2 pictures below 1 of the back of the charging coil and one of the phone. I am thinking something is NOT making contact correctly. I did replace the battery at the same time so may be an issue there. But ordered a second coil to see if I messed up the first just looking for possibilities and hoping it is simply I do not have a good connection.
Does anyone know if Wirelesss charging coil is required. For wired charging to work?
by GKJarhead
did u use the disassembly guide on this site?
to answer your question if the wireless charging is apart of that circuit, theres a chance that the corded option wont work as well. but dont quote me on that.
Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement
by Logixal
Am not finding anything useful, but I replaced a wireless charging coil in an android before and accidentally ripped the ribbon for the battery temp sensor. Would power up and run fine but refused to charge.
by brandon k
@logixal yes I followed that guide.
by GKJarhead
Ok so new recommendation. If it does not charge after putting together. Try a different charger. Before tearing it apart again.
by GKJarhead
