Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
Boot Issues: MacBook Pro boots with dark grey screen and boot issues
Ok so I have a macbook pro early 2010 15” i5 620m I can get this to boot from an SSD or USB drive but it wont boot from a hard drive, I’ve replaced c9560 and can get to the desktop where graphics acceleration, sound, usb work, full keyboard fine everything as expected.
My issue is the dark grey boot screen I cant get it out of that mode and it wont respond to normal keyboard prompts like holding option for boot selection or cmr+r for recovery mode. I also cant install an OS after booting to USB it allows me to do the install but then wont boot from the hard drive or ssd. Drivedx shows a faulty interface cable with errors but after replacing the cable itself I still have these errors. PS the SSD install was done on another machine as I cant install on this one.
Add a comment
1 Answer
Most Helpful Answer
My first suspect is your hard drive I/R cable that was not designed for the speed of an SSD. Next check to see if the SSD is backward compatible to SATA II. Most SSDs are only SATA III.
Score 1
1 Comment:
What you're saying doesnt make sense, the sata cable was designed for SSD apple shipped this laptop with them and my ssd is working at sata 2 it says so in negotiated link speed.
My issue is a hard drive wont run on this. I'm assuming its a bad capacitor/bga chip on the logic board but dont know where to look.
by
Add a comment
Add your answer
MacBook medic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 38
