2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Spilt water on MacBook, but cannot remove battery
I spilt some water which has gone inside the computer. I stupidly tried swithching it on before allowing to dry. It came on shortly and then went off. I have removed the back cover and want to remove the battery as recommended in other solutions. I cannot do this however as I do not have a tri-wing screwdriver.
1 Is it really essential for me to remove the battery?
2 Is there a way to remove the battery without a tri-wing screwdriver?
1 Comment
I have managed to remove the battery. Should I leave the bottom cover off while the computer dries?
by
Add a comment
1 Answer
Most Helpful Answer
A screwdriver from Radio Shack is a lot cheaper than a logic board replacement.
Score 2
5 Comments:
Unfortunately I live in Zimbabwe and its 9p.m at the moment.
by
Ouch! Now is the time to improvise a tri-wing somehow. You do need to remove the battery. Good luck.
by
What, no Radio Shack in Zimbabwe, what's the world coming to? ;-)
by
Got the battery out with a flat head screwdriver
by
Here's the guide on water damage: Electronics Water Damage
by
Add a comment
Add your answer
Wilson Luke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,949
