The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Clothes still wet after spin cycle-no error code
Washer does not seem to go into "high" spin cycle and leaves heavy item wet at end of cycle. Tried to extend spin cycle, and tried to re-run entire wash cycle with no improved results.
Score 1
2 Comments
The first thing I would try is to use a smaller, lighter load. The load may be so heavy it can't get up to speed.
by
I ran the small bathroom rug back through wash cycle with other items & it finally spun correctly. Thanks!
by
Add a comment
Chosen Solution
This can be caused by any one of these:
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Let us know if it starts happening again for more detail.
Score 2
Add a comment
The washer was working fine then a pop and rubber burning smell. Now it has the same symptom as above
and I only have a towel in the washer and it does not get to a high speed spin. It toggles back and forth to a relative slow spin for a little stops and then changes directions and keeps doing that and then finishes as if all went ok
Thanks Stan B
Add a comment
Add your answer
Ybsul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,699
