Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20011 Questions View all
Lost S/N after replacing the battery
I have a mid 2012 MacBook Air
I just swapped out the battery and updated to High Sierra and upon checking specs AFTER that I noticed serial # unavailable.
Which version of the Blank Board Serializer do I need to run?
Thanks so much for your help!
Add a comment
1 Answer
Most Helpful Answer
The Blank Board burner won’t help you. Once the board is set with a S/N you can’t alter it. Just like an egg you can’t break the shell twice ;-}
Lets first reset NVRAM Reset NVRAM or PRAM on your Mac
You may need to re-install the OS as well for the firmware updater to fresh things.
Score 1
2 Comments:
but there IS NO SERIAL NUMBER - i'm not trying to alter it, i'm trying to ADD ONE :)
by
Replacing the battery won't erase or alter the systems S/N.
Did you reset NVRAM?
by
Add a comment
Add your answer
decker5 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 150
