Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
iMac 21.5" EMC 2428 - Black Screen
Hi there
I have a 21.5” mid 2011 Imac, its the 2.8ghz i7 version EMC 2428.
The problem started a few weeks ago. I was away from the computer for 30 minutes and when I came back the screen was grey. I powered it down and on restart the screen remained Black. Checking online I found that the cure for this was a PRAM reset, I did this and sure enough the computer booted up as normal and all was good again.
It was fine for a couple of weeks, but it happened again. I powered down the computer and when restarting the black screen happened again. I powered down again and tried to start it up again with the PRAM reset, however this time the Keyboard isn’t being powered from the USB ports, so there’s no way of doing it.
I have tried an SMC reset and have also tried replacing the powersupply to no avail. The Imac seems to start up, hardrive starts up but there is no chime. I have shone a light on the screen, but cannot make out anything on the screen. The 1st and 2nd diagnostic lights are on inside.
Any ideas on what might be the culprit?
Cheers
Kieran
Add a comment
1 Answer
Chosen Solution
Sounds like a failed GPU. This is well know on the 2011 27” but not so much on the 21.5”
To confirm, hook it up to an external monitor.
Apple Radeon HD 6750M graphics card
Apple part # 661-5944 & 730-0629-A
iMac Intel 21.5" EMC 2428 GPU Card Replacement
Score 3
2 Comments:
Thank you so much Mayer!
Changing the GPU worked and I have a working Imac again!
I’m eternally grateful my friend
Kieran
by
@kizzer Glad it worked for you ;-) If this solved your problem, please accept my answer. Thanks
by
Add a comment
Add your answer
Kieran Heighes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 317
