The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
MacBook Air runs off of charger, but not battery, help
My MacBook Air won’t charge and will only run off of the plug. As you can see in the image, it won’t charge at all. Could this be as simple as just replacing the battery or something worse. Even though it’s an old battery, it seems like a low amount of cycles to just completely die.
Add a comment
1 Answer
Chosen Solution
Low battery cycles indicate the battery has been used quite little in its life. System clearly reports you have a battery failure and it’s condition its poor. With this data I wouldn’t be surprised battery was left drained for some time and voltage dropped below the safety threshold where battery charging is prevented by the system. I believe a battery replacement would be the first step to take here.
Score 4
Add a comment
Add your answer
Saiken will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 169
