What is the solvent that removes battery
Can you please tell me what is the solvent that loosens the battery is so I can attempt removal before buying a new battery.
Hi @secretuser
This a good guide you can follow :)
How to Use iFixit Adhesive Remover
Is the iFixit adhesive remover just isopropyl alcohol?
Cheers
The methanol (denatured alcohol) is safer for you and the plastics in computers. It worked fine for me. A bit stubborn and the battery packages get a bit twisted, but they didn't rupture. I used plastic spudgers to pry up gradually. Work from the top edge nearest the bottom of the computer. Spraying in the alcohol with a small plant sprayer. Tilt to allow the alcohol to reach the adhesive strips.
The acetone might be faster and easier, but even with ventilation there are the fumes.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 27
All Time: 1,798
