The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Questions View all
Dropped MacBook power button keyboard trackpad not responding
Dropped Mac air 13 inch (1466)
keyboard and trackpad not responding
power button not responding
Cannot reset smc or pram
other than that seems to be running fine
fan seems to be running overtime though
charger still working
Update (02/14/2019)
Drilled open stripped screw. Detached and reattached trackpad cable. Good as new
never turn your computer over unless battery is screwed in :)
Add a comment
Sounds like you really need to reset NVRAM/SMC. As your keyboard/trackpad aren’t functioning you could try to connect an external keyboard.
Follow this to connect a random USB keyboard *can even be a windows one*
https://www.maketecheasier.com/set-up-us...
Or if you have a bluetooth keyboard follow this:
https://www.wikihow.tech/Connect-a-Keybo...
1 Comment:
I have never been able to zap the PRAM using an external keyboard.
by
Add a comment
See if you can get it to spontaneously reboot by disconnecting the battery from the logic board, also disconnect the mag-safe. Press and hold the power on button for 10 seconds. Reconnect the battery and mag-safe. It should reboot as soon as you do the you can better test the keyboard and trackpad.
1 Comment:
This is what I’m hoping to do
The last remaining pentalobal screw on the cover is stripped and won’t come out
Too deep to use pliers
Tried opening it with a rubber band and tried superglue too
Waiting on a drill to remove it
by
Add a comment
Add your answer
Aman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 303
