Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
I ordered a screen replacement part. Trouble replacing it.
Hi,
I ordered screen replacement part. I don’t know why it has yellow overlay from inside.
Is it supposed to be glue, that needs to be melted or is it just an overlay?
My iphones screen is cracked and I want to replace it. But it is more complicated than I thought it is and I have trouble removing cracked screen piece from LCD.
1 Comment
Thanks for the answers. I did a little research. Yes it’s really difficult. Definitely the best option is to buy entire front screen with LCD and camera ect.
by
Add a comment
Chosen Solution
Peeling off LCD and re-bonding it on newer front glass is not DIY work. You will need professional equipment and skills, which can easily cost many times more than the phone itself.
The cheapest way is to glue the shattered screen onto a flat panel, get ultra thin wires, remove the side bezel, heat up the display the use the wire to cut from flex cable end, slowly cut the LCD off the front panel. The use adhesive solvent to clean the remaining adhesive.
Then you need professional fixture to align the LCD on replacement frame, then stick down the LCD. You will need a vacuum chamber to remove air bubbles, so I suggest you never do this on your own.
Score 4
Add a comment
The problem here is that you ordered just the glass without the lcd
Here is a list of missing equipement you need:
  1. LCD separator machine : $50
  2. Glue and Polarizer remover: $100
  3. Laminating and bubble remover machine: $150 to $1200 (depending on the scale of your business ;)
Or you can order one with the LCD already glued in from iFixit, eBay or Amazon
iPhone 5 Screen Image
Product
iPhone 5 Screen
$34.99
Score 2
Add a comment
Add your answer
Andre will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 52
