The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
Why I can't find 3G SIM Slot in my Motorola Xoom?
Bought Motorola Xoom black 32GB, but not just able to find the 3G SIM slot anywhere.
Score 1
Add a comment
Most Helpful Answer
If you bought your Xoom from Verizon, it will have no SIM card slot. Verizon's CDMA network doesn't use SIM cards. Also, if you bought the Verizom model, it will only work on Verizon, and not another carrier. There is also a WiFi-Only Xoom, and it does not have a SIM slot.
Score 3
1 Comment:
Was upvoting you, agreed, left, then remembered Xoom has LTE- thus it would have a sim card slot (quick google search confirmed this). But you still get the upvote because it's likely a wifi model, but also there's no "3G" sim slot, only "4G"
by
Add a comment
I have a wifi model and it *does* have a sim slot, in the same place as the microSD slot. Neither of them work on mine....--yet--
Score 1
Add a comment
Mine is a referbished Verizon model. It has wifi and an empty sim slot by the SD slot. I only use'wifi for now but when I was talking to Verizon they said I can get 4g on it. Also, on my wifi scan screen it always shows me the Verizon carrier and strength. I also think that my map/GPS can use the Verizon network to download maps even though I don't have service because no matter where I am I can literally watch the map fill in as it downloads.
Add a comment
so are u meaning to say, the xooms that has gone tru a 4G LTE upgrade, are capable of running a 3G sim card overseas...?
Add a comment
The SIM card slot is right beside the SD card slot. They are accessed behind the same "door" on the device. The SD card and SIM card fit almost back to back.
The SIM card rests in the door/carrier when installing or removing.
See the picture here: iFixit Xoom picture
Add a comment
Add your answer
Bikash will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 4,490
