Repair and disassembly guides and support for dish washing appliances.
707 Questions View all
power surged and then the e2 f2 code started flashing
My dishwasher is only about a year and a half old. We had a bad storm yesterday...my power surged and then the e2 f2 code started flashing. Did the reset, took the door off and checked connections...still flashing. Do I randomly start buying parts? How do I check to see if it’s something I can fix? I am handy, but appliances are new territory for me. All info. is appreciated.
Update (10/25/2018)
Update (10/25/2018)
Score 1
2 Comments
We have the same model and issue, did you come up with a solution
by
I have the same model and same problem. Did you get it fixed?
by
Add a comment
Most Helpful Answer
The e2 f2 error usually means main control board is not getting correct signal from the user interface. Turn off power/breaker, remove screws holding inner door liner, remove liner and check/secure/clean all wire connections from front interface and main control board. The number you gave me an oven, please check it for accuracy.
Score 3
Add a comment
In cases like this, the control module has been effected. This can be as simple as an open internal fuse or more complicated like a smoked controller IC. In either case, knowing the exact make and model is critical. Please update this with the make and model. Also, a Google search of the model number and the keyword “parts” should get you to a site to check for parts availability. If you can post a picture of the control module, we may be able to see a damaged part that can be replaced as a start.
Dan
Score 1
1 Comment:
Thank you. I’m adding a comment below with some pics.
by
Add a comment
Replaced the control module
Score 1
Add a comment
Add your answer
deew1015 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 49
All Time: 3,231
