Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 Questions View all
Question Closed
Compatibility of 12" and 15" batteries/charging
I need a way to charge my G4 12" PowerBook batteries, at least for data recovery and diagnostics. The 6-contact connectors look the same for the 15" and the 12". If I connect a 12" battery contact-by-contact to the 15" battery socket, is it most likely to charge successfully, do nothing, or explode?!
I have no further information on this question, alas! But since I have borrowed a 12" G4 and have successfully recovered the essential data, my question is now only of "academic" interest.
2 Comments
Why don't you run the comuter just with the power adapter and without the battery?
by
Remacberlin, The power from the working power adapter neither charges batteries nor powers the laptop.
by
Add a comment
Chosen Solution
You should consider buying the TruePower universal battery charger made by Fastmac. I have one to charge my spare batteries and it's working very well. Here's the web link:
http://store.fastmac.com/product_info.ph...
Score 1
Add a comment
Most Helpful Answer
I don't believe this will work, but to be sure please list the part numbers from both batteries as well as exactly which two machines you have.
Score 2
2 Comments:
Thanks, Mayer. The target machine is EMC 2030 with battery 825-6431-A. I had wanted to charge it with my A1001. The battery in the latter is a replacement one with part number CB10778A.
by
The 12" machine is a :
Apple PowerBook G4 1.5 12" (Al) Specs
Identifiers: 12-Inch - 1.5 GHz - M9690LL/A* - PowerBook6,8 - A1104 - 2030
I don't know what the 15" machine is. The replacement part number netted nothing on a web search.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 486
