Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Screen wont go dark
I replaced the screen. Everything works fine touch color etc. But when i am on calls the screen doesn't go dark like sleep mode and i keep accidentally ending calls while on the phone. I do not know why please help?
Score 1
Add a comment
1 Answer
Chosen Solution
Your proximity sensor may not be working. If you cover the sensor when the phone is on call it should go dark, which is similar to you putting it close to your face/cheek during a call.
Open the device and check your work. It could be one of many things.
-Cable is not completely seated
-Damaged cable
-Sensor failure/defect - Good to test on another device to make sure.
- damaged pins on either board or cable
good luck
Score 4
5 Comments:
I will try this. I’ve done many repairs before never had this happen so I had no idea why. Thank you for the help!
by
You would be surprise how silly some errors may be. Sometimes I forget to connect the battery and I go into panic mode thinking the phone is compromised, haha.
by
@juax if the cable is damaged what cable is it? Just the same as camera or a different cable?
by
Old Post but proximity sensor isn't fitted correctly. Pain to fit correctly. No cable required.
by
Add a comment
Add your answer
Dalton Towe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 479
