Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Wifi/Bluetooth assembly upper screw stripped beyond recognition
The upper screw which also holds the display assembly is stripped to the point that it's basically round, similar to the bolted screws on the mainboard.
The "rubber" / "glue" methods are out of the question.
Do you have any real suggestions for me?
I haven't tried with a drill bit yet. Should I? If yes, which size?
Add a comment
1 Answer
Most Helpful Answer
Are you talking about the screw in step #9 of this guide?
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
If so try using these: Screw Extracting Pliers
Screw Extracting Pliers Image
Product
$19.99
Score 2
Add a comment
Add your answer
Mihai-Alexandru Cernescu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 202
