Restore error 4013. No idea what now.
Okey dokey. so at first I kept repeatedly getting the Red screen of death. Problem solved by disconnecting front camera. but now, It gets to "waiting for iPhone" and then the iPhone reboots and iTunes spits out error 4013. I then tried 3u tools firmware flash, I still get stuck at 19%. I have tried DFU Mode. no help. So then in 3u tools I clicked "exit recovery mode" and the phone went into an infinite boot loop which I had to force restore mode to stop. I am so confuzzled.
@oldturkey03 @avanteguarde @mayer
Update (02/19/2018)
OK. So Upon further inspection I found the water damage indicator near the SIM card was red while the 2 others were white. So I am not sure whether it was the indicator that failed or not, as it is my grandfathers phone. he says he has never spilled/dropped it in water. everything looks clean with the exception of my fingerprints on some of the parts.
Update (02/19/2018)
I got the log from 3u tools.
Activation of device used in:
Used for activating the new unactivated iDevice
Used for activating the flashed unactivated iDevice
Activation supports below iDevices:
iPad1\2\3\4\mini\mini2\mini3\mini4\Air\Air2\Pro
iPod Touch2\3\4\5\6
iPhone3G\3GS
iPhone4\4s
iPhone5\5c\5s\SE
iPhone6\6 Plus\6s\6s Plus
iPhone7\7 Plus
Steps of activating iDevice:
1.Insert the SIM card into iDevice(iPad, iPod ignore this step), SIM card of corresponding carrier needs to be inserted into the locked iDevice
2.Please make sure iDevice under the normal status
3.Please connect your iDevice to your computer using the USB cable
13:42:48 Detecting AppleMobileDevice service
13:42:48 Waiting for iDevice connect in normal mode
13:42:58 Operations are failed
13:42:58 Elapsed Time: 00:00:10
Below devices support to query shsh:
iPod Touch2, iPod Touch3, iPod Touch4, iPod Touch5, iPod Touch6
iPad1,iPad2,iPad3,iPad4,iPad Air,iPad Air2,iPad mini/2/3/4,iPad Pro
iPhone3G,iPhone3GS,iPhone4,iPhone4s,iPhone5,iPhone5c,iPhone5s,iPhone se
iPhone6/6s,iPhone6p/6sp,iPhone7/7p,iPhone8/8p,iPhoneX
Steps to enter DFU Mode:
1. Keep iDevice in Normal Mode or Recovery Mode, plug USB cable (please don't use USB extension cable)
2. Hold HOME button(iPhone7/7p hold Volume Down button instead), then hold POWER button until the screen is blank
3. Release the POWER button after about 4 seconds, but keep holding the HOME button for about 10 seconds
iPhone8, iPhone8 Plus Steps to enter DFU Mode:
1. Plug an original USB cable,quick-press Volume "+" button, then Volume "-" button and hold the Power button.
2. When the iDevice turns off, hold the Volume "-" button, then release the Power button after 5 seconds, till it prompts "succeded".
More tutorials about iPhone8/8p and other iDevices, you could refer from: http://url.3u.com/RZbM7naa
13:45:33 Friendly reminder:
13:45:33 Please make sure iDevice turned off 'Find My iPhone'
13:45:33 The iDevice could not be activated without Apple ID after flash, if the iDevice turned on 'Find My iPhone'
13:45:33 Method to check: Settings -> iCloud -> Find My iPhone
13:45:33 Please connect USB cable to iDevice, make sure your iDevice in DFU Mode
13:45:33 Reading information from iDevice
13:45:33 ECID: 000003F4AD9F4C1C
13:45:33 Product Type: iPhone6,1
13:45:33 Hardware Model: n51ap
13:45:33 Downloading config
13:45:35 Download request file
13:45:35 Reading random NONCE
13:45:35 Querying for SHSH file on Apple Server
13:45:35 Saving SHSH file to our server
13:45:36 Generator: 0x5606b776c17ce4b6
13:45:36 Requesting shsh2
13:45:36 Saving SHSH file to our server
13:45:37 11.2.5(15D60) Apple still supports the signing of this firmware
13:45:37 Your iDevice has the following SHSH backups:
13:45:37 10.1(14B72)-----Apple server no longer supports the flash of this firmware version
13:45:37 10.1.1(14B100)--Apple server no longer supports the flash of this firmware version
13:45:37 11.2.5(15D60)---You can flash the official firmware iPhone_4.0_64bit_11.2.5_15D60_Restore.ipsw
13:45:37 Flash and jailbreak of apple device, please visit official website of 3uTools http://www.3u.com
13:45:37 Elapsed Time: 00:00:04
Below iDevices support to professional flash:
13:45:57 Friendly reminder:
13:45:57 Please make sure iDevice turned off 'Find My iPhone'
13:45:57 The iDevice could not be activated without Apple ID after flash, if the iDevice turned on 'Find My iPhone'
13:45:57 Method to check: Settings -> iCloud -> Find My iPhone
13:45:57 Please connect USB cable to iDevice, make sure your iDevice in DFU Mode
13:45:57 Reading information from iDevice
13:45:57 Product Type: iPhone6,1
13:45:57 MAIN CPU ID: 8960
13:45:57 Filename of firmware : iPhone_4.0_64bit_11.2.5_15D60_Restore.ipsw
13:45:57 Firmware Version: 11.2.5
13:45:58 Product Build: 15D60, 15
13:45:58 Image4 supported: TRUE
13:45:58 Extracting FileSystem from firmware
13:45:58 Reading ECID
13:45:58 iDevice ECID: 000003F4AD9F4C1C
13:45:58 Reading random NONCE
13:45:58 Querying for SHSH file on Apple Server
13:45:58 Saving SHSH file to our server
13:45:59 iDevice will connect to DFU Mode automatically (5 minutes in Win7)
13:45:59 Loading iBSS component
13:46:01 Reading random NONCE
13:46:01 Loading iBEC component
13:46:22 iDevice will connect to Recovery Mode automatically (5 minutes in Win7)
13:46:22 Loading RestoreRamdisk
13:46:28 Connecting with Restore Mode
2 Comments
@paperboypaddy I know you have a lot of apple devices. ever come across this?
by Aiden
Wow no I haven’t had any problems with my iPhones or anything else. So to clarify the iPhone stopped working? And had this error? I have had problems with my laptop resetting windows. But that’s completely different than a iPhone. I know it doesn’t have a warranty but maybe the Apple store can take a look at it.
by Padraic Hoselton
