{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Questions View all
Tap Water Spilled...Need to Be Cleaned or Just Dried?
Hello,
I accidentally got tap water on my computer. I immediately turned it off and gave it some time to dry. When I went to turn it back on though it wouldn’t start up. I took it to an Apple authorized repair place and they said water damage we’ll need to send it out to Apple and it’ll be $1500. I simply don’t have $1500 so I took it home. Gave it more time to dry. Powered it on and this time it started all the way up then turned off. I assume at this point there’s still some water in it (don’t ask me why the tech didn’t fully dry the inside out when he had it open...as far as I can tell he literally opened it, saw some water, closed it and said Apple has to deal with it). I realize I should have waited longer before turning it back on. At this point I’m alternating it between sitting open with the keyboard face down and at an angle with a fan running air through the vents. I’m waiting for a pentalobe screwdriver to arrive tomorrow (have some at home but I’m at school) and I’ll then open it up and investigate myself/fully dry it out. I’m hoping it’ll start back up and nothing is truly wrong (otherwise I’ll be buying a new laptop that’s in my price range and not getting this one repaired lol)...just that it wasn’t fully dry hence the issues.
Two questions...
1. Once I open it, how long should I wait to try powering it up again? As long as there’s no visible moisture am I good to try starting it up? Or should i run a fan over it with the back off regardless?
2. Should I be worried about corrosion with tap water? I know with soda, coffee, beer, etc cleaning the logic board is a must following a spill. It seems there’s mixed opinions on tap water. Should I get alcohol and clean it or just let it be?
Thank you!
Add a comment
1 Answer
Most Helpful Answer
It will need a good cleaning. MacBook Pro 13" Touch Bar 2017 Teardown
Electronics Water Damage
Score 1
Add a comment
Add your answer
John Holt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 697
